Thanks I've been looking for that list but not with vigor.
It looks like PRC T&M companies will be in trouble.
If anyone has been on the fence for gear its now or never, most any general purpose T&M instrument even in the MHz like a Rigol 1054z can be used for 'telecommunications' so its open to interpretation. Voltage control can be as mudane as a wall wart as defined below. But it much clearer that this involves at least DMM, signal sources and soldering irons/guns.
NESI or NESOI means 'not elsewhere specified or included' ergo a catch all for the category.
90302005 ...........
Oscilloscopes and oscillographs, specially designed for telecommunications
90303334 ...........
Resistance measuring instruments90303338 ........... Other instruments and apparatus, nesi, for
measuring or checking electrical voltage,current, resistance or power, without a recording device90303901 ........... Instruments and apparatus, nesi, for measuring or checking electrical voltage, current,resistance or power, with a recording device
90304000 ........... Instruments and apparatus specially designed for telecommunications
90308200 ........... Instruments and apparatus for measuring or checking electrical quantities, nesoi: for measuring or checking semiconductor wafers or devices
90309025 ........... Printed circuit assemblies for instruments and apparatus for measuring or detecting ionizing radiation
90309046 ........... Parts and accessories for instruments and apparatus for measuring or detecting ionizing radiation, nesi
90309066 ........... Printed circuit assemblies for subheadings and apparatus of 9030.40 & 9030.82
90309068 ...........
Printed circuit assemblies, NESOI
90309084 ........... Parts and accessories for instruments and apparatus for measuring or checking semiconductor wafers or devices, nesoi
90328920 ........... Automatic voltage and voltage-current regulators, designed for use in a 6, 12, or 24 V system
90328940 ........... Automatic voltage and voltage-current regulators, not designed for use in a 6, 12, or 24 V system
90328960 ........... Automatic regulating or controlling instruments and apparatus, nesi
90329021 ........... Parts and accessories of automatic voltage and voltage-current regulators designed for use in a 6, 12, or 24 V system, nesi
90329041 ........... Parts and accessories of automatic voltage and voltage-current regulators, not designed for use in a 6, 12, or 24 V system, nesi
90329061 ........... Parts and accessories for automatic regulating or controlling instruments and apparatus, nesi
85432000 ........... Electrical signal generators85151100 ........... Electric soldering irons and guns85285945 ........... Color video monitors nesoi, with video display diagonal not over 34.29 cm, not
incorporating VCR or player
I was reading an article about the new 25% tariffs that Trumps wants to put on 1300+ products/items from China, and luckily there was a link to the document.
Included in the list, apart of industrial equipments, steel/iron/aluminum there is also a lot of electronic testing gear and also components like:
85322100 ........... Tantalum fixed capacitors
85322200 ........... Aluminum electrolytic fixed capacitors
85322300 ........... Ceramic dielectric fixed capacitors, single layer
85322400 ........... Ceramic dielectric fixed capacitors, multilayer
85322500 ........... Dielectric fixed capacitors of paper or plastics
85322900 ........... Fixed electrical capacitors, nesi
85323000 ........... Variable or adjustable (pre-set) electrical capacitors
85329000 ........... Parts of electrical capacitors, fixed, variable or adjustable (pre-set)
85331000 ........... Electrical fixed carbon resistors, composition or film types
85332100 ........... Electrical fixed resistors, other than composition or film type carbon resistors, for a power handling capacity not exceeding 20 W
85332900 ........... Electrical fixed resistors, other than composition or film type carbon resistors, for a power handling capacity exceeding 20 W
85333100 ........... Electrical wirewound variable resistors, including rheostats and potentiometers, for a power handling capacity not exceeding 20 W
85334040 ........... Metal oxide resistors
85412100 ........... Transistors, other than photosensitive transistors, with a dissipation rating of less than 1 W
85412900 ........... Transistors, other than photosensitive transistors, with a dissipation rating of 1 W or more
85413000 ........... Thyristors, diacs and triacs, other than photosensitive devices
85414020 ........... Light-emitting diodes (LED's)
85414070 ........... Photosensitive transistors
85414080 ........... Photosensitive semiconductor devices nesi, optical coupled isolators
85414095 ........... Photosensitive semiconductor devices nesi, other
85415000 ........... Semiconductor devices other than photosensitive semiconductor devices, nesi
85416000 ........... Mounted piezoelectric crystals
https://ustr.gov/sites/default/files/files/Press/Releases/301FRN.pdf
