Back in December of last year, I started a thread about using epsom salt to revive SLAs.
https://www.eevblog.com/forum/chat/epson-salt-in-lead-acid-battery/The conversation drifted to using pulse-device for SLA revival a bit. Cheap desulfators are readily available but web research shows desulfation requires much better equipment. Given how cheap those cheapies are, I was going to try anyway... and I did.
Folks here may find the results interesting - measurable improvement but no meaningful improvement.
Here are the details for those interested.
I have 3 kind-of-dead SLAs and I tested it with the best of the three and it is originally rated at 22AH. This battery was not maintained for a few years, it would "fully recharge" in sub-seconds and went back to dead on any load. After trickle-charging, it was holding 12.6V and was able to deliver a few minutes of charge before January 7.
For testing, I use a 20 Watt 12V car light bulb as load. Each run, I merely timed how long it takes for it to drop from full charge 13.6V to 10.5V. It will start at about 1.7A when battery is full, down to about 1.5A at 10.5V. 10.5V is low, but according to their spec, this is what they discharge to for the 22AH number.
Except where noted, the in-between days/hours were times when the desulfator was connected - So, approx 24hrs of desulfator run between discharge runs, except the last which was 2 months of pulsing from 1/28/20 to 4/3/21.
As expected, but not as hoped; it did something, measurable but not meaningful.
Run time is measured by an INA219 with an Arduino NANO
210107 - 6m58 (before any pulsing)
210108 - 7m44
210109 - 25m57
210110 - 23m13
210112 - 29m51
210112 - 21m43 (Before interruption)
210117 - 16m41 (Resumed from interruption)
210118 - 13m50
210118 - 11m46
210119 - 10m16
210119 - 0m03 (Interruption)
210121 - 13m47
210121 - 11m41
210124 - 14m35
210128 - 11m23
210128 - 10m33
210403 - 24m09
Yeah, it improved from 7 minutes to 24 minutes of 1.5A. For a 22AH SLA, 24 minutes of 1.5A is still a dead battery. Measurable improvement but not a meaningful improvement. I do notice that at lower amp discharge, it improved more - but I did not collect data on that so I don't know for sure by how much.
Oh, a few words about the pulser. The sticker said it pulses at 10KHz, it actually pulses at whenever it can, probably when the capacitor is charged enough or something like that. As measured by my Hantek 6022BE USB Scope, I can clearly see an "attempted pulse" (very low amplitude pulse) at 64KHz. Every 4 pulses or so (that makes it around 20KHz), it builds up to a larger pulse at about 0.5V. At longer intervals, it has much larger pulse at over 1.25V. There are times that it couldn't do the larger pulse. The pulse amplitude varies depending on the state-of-charge of the battery. The scope output is attached.
I know the "Battery Desulfator" isn't going to do much, but I was hoping for a bit more. I do not regret "wasting" $15 for this thing. It was fun experimenting with it.
Edit - correction made, the battery was not maintained for longer than 12 month that I initial wrote, that was a different battery. This one was a few years...
