Author Topic: trying to upgrade HDD and clone disk fail  (Read 13346 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: April 12, 2015, 09:09:41 pm »
I have a problem. I have a mecahnical HDD with 3 partitions and windows on it. Now i want to move to a SSD but cloning has not worked because the partition alone was not bootable as that will be down to the MBR that was not copied over. What do i do ?
Offline Gringo
Re: trying to upgrade HDD and clone disk fail
« Reply #1 on: April 12, 2015, 11:35:08 pm »
Hi!  Are all partitions from windows ?  What cloning utility did you use?
Offline AlfBaz
« Reply #2 on: April 13, 2015, 01:35:51 am »
Do you know what file system the partitions are? Also what version of windows are you trying to do this from.
FDISK use to be the command of choice back in the day when FAT32 ruled supreme. It doesn't, however work with NTFS. For that you use the Windows disk management utility
Offline IanB
« Reply #3 on: April 13, 2015, 02:21:01 am »
When moving to an SSD use the cloning software provided by the SSD vendor. If it doesn't work your disk can't be cloned.
But also beware that transferring an HDD to an SSD is an incredibly bad idea. Magnetic disks have vastly greater data security than solid state disks. If you really want to do this, do a fresh OS install on the SSD and keep your important data on the hard disk as a second disk. If your data is important, don't put it on an SSD without daily backups.
  • Global Moderator
« Reply #4 on: April 13, 2015, 06:51:26 am »
Well I formated it with NTFS as the source disk is. It's a kingston disk so don't know if they have a utility.
Offline IanB
« Reply #5 on: April 13, 2015, 07:04:45 am »
This doesn't sound right. You shouldn't have to do any manual partitioning or formatting. Normally the OS installation software or the disk copying software does this for you.
When you use the cloning software it recreates the same partitions on the target disk as on the source disk and makes the target disk bootable. If you want to make an image copy of a first disk onto a second disk it is essential to use the appropriate cloning software. Otherwise it won't work. Since SSDs are special it is even more important to use the vendor supplied software to do the image copy.
Check the instructions that came with the disk, or check the Kingston web site.
Offline mtdoc
« Reply #6 on: April 13, 2015, 07:08:07 am »
I don't have a strong opinion on this but if you listen to the recent Amp Hour podcast interview with Chuck Peddle (#241), I think he would disagree.
  • Global Moderator
« Reply #7 on: April 13, 2015, 07:09:57 am »
I used clonezilla live CD and did a partition to partition copy. Maybe i need to do an image file backup and then restore the image to the new disk.
Offline IanB
« Reply #8 on: April 13, 2015, 07:17:03 am »
Well granted I have never had any issues with the storage in my phone or tablet, but my one experience with trying to put an SSD in a Windows machine did not go well. The disk cloned and booted fine and worked OK for an hour and then it went poof! and became unreadable. The data became entirely scrambled such that disk utilities could not recognize anything on the disk at all. So I accept that my experience was a sample of one, but I really can't feel secure about my data being stored in a bunch of electrons.
Offline IanB
« Reply #9 on: April 13, 2015, 07:22:27 am »
All I can say is that when I have moved old disks to new disks I have used the tools provided by Seagate, WD or Samsung as appropriate. Each time I followed the instructions from the drive manufacturer and it worked perfectly. The new disk gets recreated so that it boots just like the old disk.
« Last Edit: April 13, 2015, 08:28:59 am by IanB »
Offline G7PSK
  • It is hot until proved not.
« Reply #10 on: April 13, 2015, 07:46:14 am »
It is best to use a cloning kit like this.
https://youtu.be/8WdBp1zrePE
  • Global Moderator
« Reply #11 on: April 13, 2015, 08:12:27 am »
It's kingston they don't have a tool, I did a technical chat online and they recommended a commercial package to use. so basically I'm on my own.
Offline G7PSK
« Reply #12 on: April 13, 2015, 08:28:54 am »
Kingston supply software on a disc that comes with the SSD it is shown in the youtube link I put up previously one reason I chose that particular one. I have been looking into an SSD for my Panasonic CF19 and from what I have seen to date I am not sure that I wouldl go with Kingston.
Offline IanB
« Reply #13 on: April 13, 2015, 08:36:34 am »
Usually the vendor provided tool is a free version of a third party tool like Acronis. I have never bought a disk that did not come with cloning instructions and a link to a free tool, just like in the YouTube video. So I'm not sure why Kingston would not be offering such a tool (any more)?
Offline Kjelt
« Reply #14 on: April 13, 2015, 08:45:24 am »
Which Windows, if it is 7 or higher Windows can do this itself.
If that does not work (happened to me because the target hdd was smaller than the original) I went to a linux expert that helped me with some linux command lines activating the bootrecord, no way I remember how he did it but was 5 minutes work.
But the best way is just setup your Windows OS from scratch on the SSD.
  • Global Moderator
« Reply #15 on: April 13, 2015, 08:46:16 am »
It's 7 so how do I do it with windows ?
Offline Kjelt
« Reply #16 on: April 13, 2015, 08:54:02 am »
Just google on "windows 7 transfer to ssd"
Windows 7 has a built in backup and restore program.
You Backup your original data to an external (extra spare) USB harddrive.
You create a boot / recovery disk for Win7.
Replace your original harddisk with the SSD.
Boot from the boot / recovery disk and a utility starts up , select the external image on the USB disk.
And restore. reboot finished.
If you run into problems with the booting like a 0xC0000225, just google and you find the right solutions, like:
http://www.sevenforums.com/installation-setup/228493-windows-boot-hangs-error-0xc0000225.html
Offline amyk
« Reply #17 on: April 13, 2015, 02:29:49 pm »
If the new disk is >= in size to the old one, then a plain old sector-by-sector copy of the whole disk will just work. Something like dd from a Linux boot CD - just make sure you get the source and destination disks correct!
You can use something like gparted to resize the partitions afterwards if the new disk is bigger.
SSDs look exactly like any other type of disk to the OS. Same interface. There's some performance tweaks you can do, but otherwise it's as easy as installing a regular spinning disk.
Offline free_electron
    • SiliconValleyGarage
« Reply #18 on: April 13, 2015, 02:43:28 pm »
make sure your SSD is larger than the HDD ....
Offline G7PSK
« Reply #19 on: April 13, 2015, 02:47:07 pm »
Will the windows utility transfer all the non windows drivers as well, I want to install an SSD in a panasonic CF19 MK2. It has 32 special drivers which have to be installed in exactly the right order otherwise they will not work. I recently installed a new 500MB HD and it took nearly 3 days to sort out, I installed WIN.7 64 bit. it was originally built for Vista. I found that some of the Vista drivers worked but other would not and had to by trial and error find drivers from  the MK3 and 4 versions that would do the trick and I dont fancy having to go through that again but I gathe an SSD will make the machine a whole lot faster.
  • Global Moderator
« Reply #20 on: April 13, 2015, 03:20:38 pm »
just make sure it is a decent machine. I've put an SSD in a netbook for a friend because the mechanical drive was damaged and judging by the state of the machine it gets a rough time. It's  not that fast asa it has a crappy atom processor running at 1.66 GHz so in effect the disk is likely to be faster than the rest of the machine.
my problem is not the sector by sector copying but a lack of a boot record to make it boot
Offline AlfBaz
« Reply #21 on: April 13, 2015, 03:27:20 pm »
So you only want the windows partition on the SSD and not the other 2?
  • Global Moderator
« Reply #22 on: April 13, 2015, 03:32:51 pm »
Yes problem is the MBR is not on that partition so I'm just creating a disk full of data.
Offline Monkeh
« Reply #23 on: April 13, 2015, 03:35:27 pm »
So create the partition table you need and copy the bootblock over.
Any Linux bootdisk, the tools fdisk and dd, their respective manpages, and any of the thousands of sites which describe the format of the MBR will assist you with this.
Offline AlfBaz
« Reply #24 on: April 13, 2015, 03:48:54 pm »
Not entirely sure it's that simple, windows 7 and NTFS combined have a slightly different MBR. For FAT32 the MBR is 446 bytes of boot code followed by 4 partition structures pointing to where on the disk they are and finally the signature 0xAA55
NTFS has the bios parameter block followed by what they call the bootstrap code and finally the sig 0xAA55
What might work is to boot from your W7 install cd with the SSD installed as main C: drive, format it within the install and then quit the install. Then simply copy all the files from you windows partition over to the SSD. I'm sure there must be other ways to create a bootable NTFS drive which you can then copy you windows partition to but I'll leave you and google alone with that one ;)
