I Don't post much but i have a question on tapping in to the RX path of a TS-2000 I am sure there is quite a few amateur radio operators on here and this has to have been done before...
Ok so to start I have the software working with HDSDR and my TS-2000 so I can point and click and the radio snaps to that Freq or tunes with the VFO and the program tracks so that is pretty freaking sweet. i don't think i need to Tap in to any of the IF's in the radio as the SDRplay works good with the software and on its own.
So I need to split my Antenna from my Kenwood to the SDRplay two things that stink 1 I can get a MFJ-1708 but that's Freaking $100 and two I have 2 antenna ports.
I was thinking I can tap in to the RX path of the TS-2000 so I don't Transmit in to the SDRplay and smoke it.
i'm thinking 1 Coax with an SMA connector and a bypass cap is cheaper then MFJ-1708..
I was looking at the schematic and i can tap in before or after the first Preamp?
or I can tap in after the bad-pass filers on the lower board near the first preamp. I was thinking tapping just after the bad pass filters might be a good ida and clean up the single a bit unless there is some freq mixing going on there. In that case i can go back to tapping in around the first preamp.
i don't want to blow up my radio i'll be the first to admit i know a enough to be dangerous..
