I was playing with this IC after watching [eevblog #204], but when the display didn't turn on exactly at the Vrlow voltage, i noticed somethig curious: if you take a look at the block diagram, there is no comparator attached directly to the Rlo pin, so that means that the first led turns on at Vrlo + (Vrhi - Vrlo) / 10. That seems a little bit messy to me, like they needed to add an additional comparator, or remove the lowest resistor in the ladder.
