The problem with the remote not switching the set off was grime on the remote contacts. That is sorted out now
All resistors, and the transistor in that section are fine.
Looks like the Uc is not powering up properly (Because that 5v Line is Pulsing with the Tick-Tick-Tick when the set is in standby)
If I apply 12v, from a seperate battery, to the 7805 regulator on the powersupply board, then the remote can turn the set on and off fine.
I do not know much about how the standby circuit works in the powersupply (how we get 5v through the isolation transformer when the supply is supposed to be in standby),
but when in standby, the ticking of the powersupply is also fluctuating the supply to the 7805 regulator, and this causes the uC to hangup. As soon as the set is in running mode, the loads must stabilise the powersupply.
Any idea why the supply is not stabilised in standby?
This is one of the first projects that I am trying to get done to the end, instead of just giving up at the 80% mark, which has happened with so many other of my projects,
Thanks for all your help.
Peter
