I'm a Telecommunications Expert
if you claim that you had 2 Analogue Television sets
in the same house
connected to the same TV Antenna
Tuned to the same Frequency
and on the Same PHYSICAL CHANNEL (not TV channel)
and after all that, you claim that you saw 2 Different commercial
Sorry... Not Possible
Even if it was some Government conspiracy........... not possible
(FYI, I'm in Australia)
but, regardless of where you are in the World
yes we have Modulation Differences and Bandwidth Differences
but.. fundamentally
if you are on a certain Frequency
let me use Examples in australia. ok
let's say (i'm in Sydney) and my Antenna is Pointing towards North Sydney (Artarmon Transmitter)
and i want to watch TV Channel 7 (digital 7)
so, that's on the Frequency of 117.500 MHz (if i'm not mistaken)
and on my spectrum Analyzer (and according to the Australian Channel Plan)
this Frequency is PHYSICAL CHANNEL 6
Physical Channel Numbers are not the same as TV Channel Numbers
Eg.
this frequency that's on
Physical Channel 6
has about 7 Shows Broadcasting at the same time (Multicasting)
now when you tune in your TV
let's just use 3 of the broadcasts on that 1 frequency as an example
let's take
DIGITAL 7
DIGITAL 7 TWO
GEM
so..
DIGITAL 7 Scans in on TV Channel 70
DIGITAL 7 TWO Scans in on TV Channel 72
GEM scans in on TV Channel 73
but. they are all on 1 Frequency
but.. that's digital
you said you had an analogue TV
so, that TV Must have an Analogue RF Tuner (Assuming no Set Top boxes are connected to it )
so, if your one 1 Analogue Channel (PHYSICAL CHANNEL) or Digital.. it doesn't matter
and you scan in your 2 TV's
your 2 TV's are connected to the same Antenna
Therefore the signal that comes in on one will come in on the other
and your part of the world will have a CHANNEL PLAN FOR THE COUNTRY
Your TV's When manufactured, WILL HAVE TO CONFORM TO THAT PLAN
so.. it's impossible for you to receive 2 different broadcasts on 2 different TVs in the same premises
Here are some possible scenario's that give logic to what your saying
- Maybe 1 TV was connected to 1 Antenna Pointing in a certain Direction
and the 2nd TV was connected to a different Antenna pointing in another direction
Hence your receiving 2 different broadcast signals
- Maybe you had the 2 TV's on different TV Channels , but you didn't realize it (it happens)
- Maybe you had both TV's on the same antenna, but.. one of them was connected let's say TV Channel 2 and watching LIVE TV Channel 2
and the other had a Video Player connected with a Tape in it, and the Video Player was tuned to run off TV Channel 2
and then somone presses PLAY on the video and Vuola
you think your watching 2 different broadcasts
well, actually you are.... But they are not both live broadcasts that could also happen
but the bottom line is
there is no way under god, Not even remotely possible
that
if you have 2 TV's
connected to the same antenna
Tuned to one Transmitter
and the TV's are on the same Physical Channel
there is no way , absolutely no way at all to view 2 Seperate programs
Even if
the broadcaster wanted to play a birthday prank to scare the shit out you on your birthday and spend millions of dollars doing it.
IT'S STILL ON THE SAME PHYSICAL FREQUENCY
I don't say this word often
but...
that scenario is Simply "IMPOSSIBLE"
Even if your entire country, Changed it's channel plan for 10mins (which would never happen)
you would still be on a New Frequency, but both TV's would be on that same frequency
it's not possible
something happened that you didn't realize was happening
Video Tape
Different Channel
extra Antenna
Satellite TV
Cable TV
something else was being transmitted on the second TV
that's the only explanation
as to what and how
i'm not there , i don't know
if i was, i would know
but, there was a 2nd Broadcast signal of some nature
that's how it happens
