Hello thanks for all your interest ! I'll answer in order
I was happy of my system until I noticed that some chargers have a green led still on while mains power (220V) is off.
does the light go out if the chargers unplugged from the mains ?as it sounds like the programmable socket is using a semiconductor instead of a relay and the leakage is enough to power the leds
If the charger is disconnected form mains and device, led is off, as soon as I connect it to the device (still not connecting to mains ) the led turns on
You could easily fit a relay to disconnect the load when no input voltage is present.
thanks for the idea. I think I'm going to roll with it, I kind of feel dumb I didn't think about it on my own !!!
In this case the equipment Wnef is using is decent quality theater electronics, so it will all have proper charging circuits.
Unfortunatly some of my equipment is not good quality.
I've simplified the context to make it quick, but the full story is that we do theater on water not indoor!
we build and pilot weird boats and act on them !
The device wich has the led still on is a handheld smoke machine, very very made in china.
We have in the past bougth expensives handheld smoke machine ( 10x the price ) but due to water corrosion ( salty water will eat everything ) they don't last long and can't justify their price...
On the side note those cheap ones are not as fast to heat up but definitly do the job for the price point.
So considering your advice I think I'll built a relay station that will cut off the connection while in storage mode
