Author Topic: ultra sonic transducers  (Read 4780 times)
Offline pete gTopic starter
« on: April 07, 2024, 07:56:56 pm »
if i was going to hook up one transducer would there be any polarity concerns?
Offline Zero999
  • 0999
Re: ultra sonic transducers
« Reply #1 on: April 07, 2024, 07:58:57 pm »
It depends, but my crystal ball has gone a little cloudy.
Offline woofy
    • Woofys Place
« Reply #2 on: April 07, 2024, 08:20:08 pm »
Plastic transducer, no problem.
Metal transducer, depends:
Check the case to the pins with a multimeter. If none are connected,  no problem.
If one pin is connected, make sure it is grounded if the circuit allows or at least isolated.
« Reply #3 on: April 10, 2024, 12:17:24 am »
hi, thanks for responses. how would you hook up two or more in parallel?
Offline Zero999
  • 0999
« Reply #4 on: April 10, 2024, 07:02:51 am »
You don't.
Offline Gyro
« Reply #5 on: April 10, 2024, 08:26:21 am »
As soon as you start putting transducers side by side, you start introducing interference patterns - peaks and nulls. That is almost certainly what you don't want.
Best Regards, Chris
« Reply #6 on: April 14, 2024, 03:52:31 pm »
hi, thanks for your responses. i have a problem. nearby dog barking. i'am looking for you ee's out there for a dog bark repeller. it needs to transmit an ultra sonic signal 75 to 100 feet. dog bark repellers are legal in my state so there is no liability issues. if someone will design the circuit i can build it. please help.
Offline CatalinaWOW
« Reply #7 on: April 14, 2024, 04:02:15 pm »
Before you put any effort into building this thing, do you have any evidence that ultra sonic sounds suppress dog barking?  I know that dogs bark in response to hearing other dogs bark, and to unusual noises.  My knee jerk opinion would be that an ultrasonic noise would start dogs bothering rather than stop them.
Offline Zero999
  • 0999
« Reply #8 on: April 14, 2024, 04:40:27 pm »
You didn't say you wanted an ultrasound generator. Most people thought you wanted an ultrasonic microphone.
Please provide more information.
This is your last chance. More vague nonsense and you go on my ignore list.
« Reply #9 on: April 14, 2024, 05:33:23 pm »
sorry for my ineptitude. i need a ultrsonic transmitter (25khz) to project into my neighbors yard. approx. 75 to 100ft at a level the dogs can hear. ultra sonic conditioning of dog barking works. i suppose you would need an oscillator feeding into a high power ultra sonic amplifier and then a means of transmitting same. if i can provide more detail plz let me know.
« Reply #10 on: April 20, 2024, 01:09:26 am »
still too vague?
Offline coppercone2
« Reply #11 on: April 20, 2024, 01:19:53 am »
you should try civil discourse instead of trying to make nutty contraptions
Offline Zero999
  • 0999
« Reply #12 on: April 20, 2024, 01:08:37 pm »
https://www.ebay.co.uk/itm/374178720408?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749393&toolid=20006&_ul=GB&_ul=GB&customid=GB_159912_v1%7C374178720408%7C0.148874905896~1871765235598-g_CjwKCAjwz42xBhB9EiwA48pT714LC2T8J9MBtaf9gCWWKCXbIMr9mNhiSxw6G1TgVEc8IkK_A4qYARoCM5cQAvD_BwE&gclid=CjwKCAjwz42xBhB9EiwA48pT714LC2T8J9MBtaf9gCWWKCXbIMr9mNhiSxw6G1TgVEc8IkK_A4qYARoCM5cQAvD_BwE
« Reply #13 on: April 20, 2024, 06:22:34 pm »
well, i think i should be the one to determine if civil discourse is an option. whats so nutty about the device i propose to stop the barking?
« Reply #14 on: April 20, 2024, 06:25:32 pm »
well, i had thought it might be nice to make one . and so, i appealed to the forum members to help out, there is certainly more expertise on this forum, that making the device i propose is entirely feasable.
Offline Zero999
  • 0999
« Reply #15 on: April 20, 2024, 06:33:58 pm »
1) Plenty of people here are unconvinced about the efficacy of ultrasound at stopping a dog barking. The idea appears to be a crazy one to many,
2) It's possible to build one but why? It's cheaper to buy one and if it doesn't work, it's likely you'll be able to return it, for no more than the price of postage. This is more of a professional engineering forum, than a hobbyist one. If the best solution is to buy off the shelf, then that's the advice you'll get.
If you must go DIY, go for a tweeter, audio amplifier, a digital signal synthesis IC and microcontroller.
Offline EPAIII
« Reply #16 on: April 20, 2024, 09:55:23 pm »
Have you considered an alligator for a pet? A friend of mine did that for exactly the same reason. Except he had TWO neighboring dogs which barked all the time.
I bet that dog would be the first to go.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
« Reply #17 on: April 20, 2024, 11:02:47 pm »
didn't know about the professional, hobbiest bit. so thanks to all. i'll try elswhere.
Offline Zero999
  • 0999
« Reply #18 on: April 21, 2024, 10:17:31 am »
Don't get me wrong, we do have hobbyists here and encourage amateur electronics.  It's just we will tell you when your idea won't work and if it's easier to just buy it. In many cases, asking a question indicates the poster lacks the experience to make it.
I do encourage you to visit other forums. You'll mostly get 555 timer circuits, based on the data sheet. You could spend $$$ and time on this and it most likely won't work.
Here are some tweeters similar to those used in ultra sonic repellers.
https://www.cricklewoodelectronics.com/Piezo-Tweeter-150W-max.html?gad_source=1&gclid=Cj0KCQjw8pKxBhD_ARIsAPrG45nlnPJMNdaZ4InSWETJapUdWX6wZxtdpwoLmg5MfvVGFyH9SuHxAhgaAg70EALw_wcB
https://www.ebay.co.uk/itm/355572011302?chn=ps&_ul=GB&mkevt=1&mkcid=28
I suppose learning won't work is part of the learning experience, but why not listen to experts who've done this professionally? It will save you time and money. I suppose not listening, then failing and realising you had good advice is also part of the learning curve.
« Last Edit: April 21, 2024, 11:35:49 am by Zero999 »
Offline CatalinaWOW
« Reply #19 on: April 21, 2024, 03:12:08 pm »
I would also suggest that you need to supply the non electronics expertise needed.  Can't suggest transducers without knowing what power level is needed, which in turn requires knowing how loud the sound needs to be.
« Reply #20 on: April 21, 2024, 03:22:25 pm »
totally agree with the advice given. will look into buying one. the only problem being, none of the commercial ones  have the range i need.
Offline Zero999
  • 0999
« Reply #21 on: April 21, 2024, 04:05:46 pm »
Perhaps it's because you'll need an enormous amount of power, which might mean it's unsafe to be too near it?
Sound follows inverse square law, so to double the effective distance, you'll need four times the power.
https://personalpages.manchester.ac.uk/staff/richard.baker/BasicAcoustics/4_inverse_square_law.html
« Reply #22 on: April 21, 2024, 04:18:08 pm »
yes, there could be a danger. but, being 87 i do need my sleep.
The following users thanked this post: boB
Offline PlainName
  • Country: va
« Reply #23 on: April 22, 2024, 04:30:44 pm »
Perhaps an alternative solution would be to find something that encourages the dog to bark. Sooner or later it will get  hoarse, or the owners will be thoroughly pissed off with it (it is closer to them than you... inverse law...). Perhaps some clever control to start the encouragement the moment it stops barking and just wear the thing out.
Or... get a cockerel. Two might be better since they will be in competition, although that works best if you have hens too. But think of the eggs for breakfast!
« Reply #24 on: April 22, 2024, 05:51:20 pm »
Easiest is piezo tweeters, though you will need a few placed in an array, with a driver able to drive the 20uF or so of capacitive load they will present. Easy to assemble, and they do have a response out to around 30kHz, though your drive voltage is limited to around 30V or so. 7in by 3in ones are common for disco use, and cheap to buy for under $10.
