Oddly enough, I just got my first scope less than a week ago (Tek 465B) and had to fix a problem with one of those rods. The A channel variable gain knob was unresponsive. When I opened it up I found that the rod was fiberglass, and the coupler that tightened it to it's pot was broken on one side. I saw that I could fix it rather quickly if I drilled a hole in the rod, but I wanted to find a solution that didn't compromise the original parts so that it could be reassembled properly if I ever got a proper replacement coupler.
I used a . . . I'm not sure what to call it. It's used in cooking, wooden, about 1/8" diameter by 12" long, kind of like a kebab spear or a giant toothpick. I trimmed it to length against the fiberglass rod, used a pin drill that I use for circuit boards to drill a hole in it, and fastened it to what's left of the coupler. Works ok if I'm gentle with it, and it was enough to verify that the circuit works.
I assumed that if I used a metal rod (which I have a pile of) it would have caused problems with stray signal pickup. If I'd wanted to do a bit better job I'd have headed down to the hobby shop nearby and chosen a stronger wooden dowel of the right thickness, or perhaps even cannibalized a kite kit for an appropriate fiberglass rod.
What really stood out to me when I had the scope open was the high quality of construction and care given to details. I saw, for example, the exact device I had in my head when reading about temperature compensated transistor pairs: a small metal heatsink/clamp like device that thermally bonded two adjacent transistors together. It's obvious that Tek started with a good design and
didn't allow heavy nickel and dime cost cutting to compromise the design. I suppose it's worth considering that (according to what I've read) the B series wasn't produced for long due to it's high cost of construction.
