Author Topic: UNIX rollover - why 2^31 signed and not 2^32 unsigned?  (Read 2345 times)
Offline CirclotronTopic starter
« on: May 04, 2022, 11:55:47 pm »
We all know that if nothing is done, UNIX will conk out early 2038 because there are 2^31 seconds from 1 January 1970 till 19th January 2038. My question is - why was a signed integer that has a maximum positive value of 2^31 used as the seconds counter when an unsigned integer value of 2^32 could have been chosen? That would give a counter twice as long. The only reason I can think of is, being signed, it could also deal with negative numbers, that is, dates earlier than 1 January 1970. Does that make any sense at all? Is that how it works?
https://en.wikipedia.org/wiki/Year_2038_problem
Offline Someone
    • send complaints here
The following users thanked this post: Circlotron
Online BrianHG
    • LinkedIn
Re: UNIX rollover - why 2^31 signed and not 2^32 unsigned?
« Reply #2 on: May 05, 2022, 01:09:51 am »
I just feel it's sad that those who wanted to create an ultimate OS for everyone would settle on a time format which couldn't even make it to 2050, let alone 2100.  Maybe this short-sight means unix should be dumped?
Offline langwadt
« Reply #3 on: May 05, 2022, 01:17:13 am »
isn't most platforms and timestamps 64bit already?
Online BrianHG
    • LinkedIn
« Reply #4 on: May 05, 2022, 01:32:37 am »
It's not that, it's that they begun with only 31bits of time expecting that they would burn, fail and be completely forgotten by 2038.
Online Monkeh
« Reply #5 on: May 05, 2022, 01:53:59 am »
You seem to have a very warped idea of how Unix came to be.
The following users thanked this post: hans, Siwastaja, tooki
Offline timenutgoblin
« Reply #6 on: May 05, 2022, 01:54:27 am »
Yep, we're all doomed and there is nothing we can do to stop it.
link to the video here: https://youtu.be/l4UFQWKjy_I
The following users thanked this post: BrianHG
Offline ejeffrey
« Reply #7 on: May 05, 2022, 05:34:22 am »
Yes.  While UNIX timestamps themselves are rarely negative, it's common to subtract two timestamps to compute the delta between them.  If you do that with unsigned types in C the result will be unsigned and wrap to a large positive value for negative deltas.
C was also built around the idea of having the basic integer types be of an unspecified width that could be changed to fit the machine in question.  To the extent anyone in the 70s worried about Y2.038k, they probably just assumed that changing the type would be no problem.  The expectations of binary compatibility and stronger portability were a lot less then than now.
The following users thanked this post: eugene
Offline daqq
  • Country: sk
    • My site
« Reply #8 on: May 05, 2022, 06:42:37 am »
Like most bad things: It seemed good at the time.
Offline JohanH
« Reply #9 on: May 05, 2022, 06:54:46 am »
In *BSD and Linux most things are fixed. And what is not fixed is planned for.
But there are a lot of old software running out there. I've even seen old SCADA type of software on Windows that rely on 32-bit timestamp for some functions. I verified by changing computer date and time and a certain function stopped working in 2038. Nothing critical in this example, though.
There was some joking why Germans wanted to stop their nuclear power plants before 2038...
Offline Bassman59
  • Yes, I do this for a living
« Reply #10 on: May 05, 2022, 03:44:49 pm »
Thank you for writing Y2.038k instead of the more common and completely incorrect Y2K38.
Offline nightfire
« Reply #11 on: May 05, 2022, 09:28:54 pm »
No- back then, Memory and resources were scarce, and by that time the decision was made, the designers were full aware that it would have some limitations- but by year 2038 there would be more powerful systems available, so it was expected that by then a solution/updated version would be available.
Offline SiliconWizard
« Reply #12 on: May 05, 2022, 09:48:39 pm »
Yeah, sounds reasonable. And actually, the updates have been there for quite a while already.
Those still running old software for whatever reason, even if the reason is a good one, are responsible. Not the authors of 50 years ago. Come on. =)
Offline PlainName
  • Country: va
« Reply #13 on: May 08, 2022, 09:05:04 pm »
For an EE, why would the second not be correct? In fact, wouldn't Y2038 be the actual correct way - Y2K was, after all, just an abbreviation that appealed to computer types and could be mistaken for meaning Y2024.
Offline langwadt
« Reply #14 on: May 08, 2022, 10:24:40 pm »
Y2K38 would 2380, so if anything it should be Y2K038
Offline PlainName
  • Country: va
« Reply #15 on: May 08, 2022, 11:49:25 pm »
Ah, good point :)
Offline Nominal Animal
« Reply #16 on: May 09, 2022, 02:39:07 pm »
Not 2024, 211=2048.
Offline PlainName
  • Country: va
« Reply #17 on: May 09, 2022, 03:04:37 pm »
Not 2024, 211=2048.
Just checking if you're awake  :P
The following users thanked this post: Nominal Animal
Offline eugene
« Reply #18 on: May 10, 2022, 06:10:07 pm »
We have 14 years to convert to 256 bit time stamps. That should work until our sun burns out or goes supernova or whatever. If you move to another solar system then you're on your own.
90% of quoted statistics are fictional
Offline hans
« Reply #19 on: May 10, 2022, 08:54:26 pm »
And so did Microsoft never thought they would stay around long enough to reach Windows 9 :horse:
Isn't any technology going to have limitations that were unforeseen or planned to be part of future drafts? I mean C is a wonderfully simple language.. but you wouldn't want to program absolutely everything in it neither.
