Re: Relays Between Charger and Battery
The amount of current that an LED uses is very small, probably 10 mA or less. The coils of those relays will consume dozens of mA while they are energized. So, depending on the actual currents and charging times, you may use more power with the relays than without.
A solid state relay may be a better choice. Read the specs.
On the other hand, if you are going to go to the trouble of turning the power off, assumedly by manual action, then why not just use a switch instead of a relay. One double gang switch with high enough ratings to switch the incoming power could also switch the DC output of the charger on a second contact. And there would be no extra power drawn by a relay's coil or a solid state relay's circuitry. On would be totally on, both AC power and DC output. And OFF would be totally off. If you want to completely isolate the DC, you can use a three gang switch. Win! Win! situation.
If you do implement either the relays or my switch suggestion, please do follow good construction practice. To the greatest extent possible, keep the AC power and the DC as separate as possible in the box. Yes, do use a box. An idea for better separation at the switch would be to use one with another set of contacts. Use the first gang's contacts for the AC. Then connect all of the second gang's contacts to ground. Have a grounded, separator inside the box that is attached to all four exterior faces of the box and that jumps across the switch contacts at the location of the second gang, which is also grounded. That creates two separate chambers inside the box, one for AC power and the other for the DC. A third and possibly a fourth gang of the switch would then be used for switching the DC.
That may be a bit of over-kill, but it would certainly provide maximum safety. Something similar could be done if a relay is used. Coil connections in one chamber and the DC in another, with a grounded separation panel between them.
Modern batteries can hold a charge for months. They can be put on the charger after being used and taken off the next day. They should then be fully charged. And will probably stay above 95% of full charge for at least a week or two. Monday morning, first thing after getting your coffee, go and put all the charged items on their chargers. Then, when you finish that coffee, go back and take them off. They will be OK for use at any time later in the week.
