Based on the lack of objections, I can conclude that I am right.
I did not want to participate in this thread, but boy is someone here full of himself and blind for what is obvious.
The fact that you can't even see analogies between different technologies proves the above.
There is no need to go deep into the given formulas, the real world test shown in the first video you presented gives enough evidence that it does not bring what is expected. The mechanism is stopped with little effort of the guy in the water next to the device, so how can it then drive a generator to provide several KW of electrical energy?
But my conclusion of this whole thread and the other one about the use of waterwheels is that you are an attention seeker, and most of the frequent users of this forum don't want to play with you.
1. There are definitely analogies between electric current and water flow. But they are never complete.
This is exactly the case if you haven't noticed.
2. The video shows a turbine with a height of 50 cm. If you had bothered to delve a little deeper into the topic, even for a minute, and did not make hasty conclusions, you would have seen that as the height of the turbine increases, the power increases to the cubic degree.
Look here
https://www.eevblog.com/forum/chat/unusual-design-of-a-free-flow-hydropower-station/msg5281537/#msg5281537Pay attention to the numbers on the tables there. They are even specially allocated for you.
3. I don’t need your attention and I’m not going to play with anyone. But you still play...
But I’m not dragging anyone here on a lasso.
If you don't want to play, pass by. The topic about cats is just for you.
