Author Topic: unusual motor very interesting  (Read 2463 times)
Offline siliconmix
  • Country: wales
« on: June 12, 2012, 08:26:04 pm »
Offline G7PSK
  • It is hot until proved not.
Re: unusual motor very interesting
« Reply #1 on: June 12, 2012, 08:34:07 pm »
Those bearings wont last very long, I can hear them rumbling already.
Offline MikeK
« Reply #2 on: June 12, 2012, 08:54:37 pm »
He's passing current through the bearings?  Oh gawd.
I think Honda had a problem a while back where the electrical system was grounding through the front wheel bearings, causing them to wear out well before their time.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: June 13, 2012, 12:30:42 am »
Fun but utterly useless - More info here :
http://electricstuff.co.uk/bbmotor.html
Day Job: Mostly LEDs
Offline Unclegummers
« Reply #4 on: June 13, 2012, 12:43:44 am »
Is that FREE ENERGY?!?! 8)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: June 13, 2012, 01:06:27 am »
free energy to the air. 25A to get a usefull rotation? my car cigarette lighter butt is better.
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
Offline siliconmix
  • Country: wales
« Reply #6 on: June 13, 2012, 07:42:02 am »
is that your site mike ? .but what if every other bb is a magnet ? pmsl :)
Offline G7PSK
« Reply #7 on: June 13, 2012, 07:46:29 am »
If I read the operation principle correctly as the bearings heat up the whole thing will become less and less efficient to the point that when the balls are as hot overall as they can get before melting and there fore no more thermal expansion and more importantly enough residual heat to prevent rapid contraction after the expansion it will grind to a halt.
« Reply #8 on: June 13, 2012, 03:34:05 pm »
I have done that, it works well, if rather inefficiently. Just remember to use steel endcap bearings, or remove the rubber endcaps, otherwise there will be fun. Works best using a 12V car battery, and around 5m of 2.5mm bare steel wire as a ballast resistor. The wire glows red during startup ( until you move the shaft to start) and then cools down to just burning hot but not glowing. The motors generally will run for 5 minutes before something fails, either the cage melts, the balls drop out or the raceway arcs enough to seize.
