Author Topic: Upper-class vs peon capacitors  (Read 1036 times)
Offline PlainNameTopic starter
  • Country: va
« on: December 06, 2021, 06:35:02 pm »
Just looking around at supercaps for potential use (currently using battery to hold a system up for around 10-20 seconds) and I am seeing a range of prices (there's a surprise). For nominal 5V/1.5F good examples of the ranges are the RS Pro @ 95p each at 5-off:
1342394-0
and the Eaton Bussmann @ £7.99 each:
1342400-1
The RS jobby has worse tolerance but, other than that, what might be justifying the price difference?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Upper-class vs peon capacitors
« Reply #1 on: December 06, 2021, 06:48:27 pm »
Imagine you can find cheaper than brand-name of the low-ESR kind too, but that's the likely main difference between the two kinds shown.  The coin type are, AFAIK, more traditional construction with high ESR, suitable for CMOS backup over some hours/days/months, and essentially no real power draw (ESR >kohms).
What ESR do you need?  For a 20 second time constant I would guess the latter type, that's quite a lot of current draw to discharge a farad at, as backup capacitors go.
Seven Transistor Labs, LLC
Online wraper
  • Country: lv
« Reply #2 on: December 06, 2021, 06:52:16 pm »
First supercap is only good for tiny current due to very large ESR. Also it's produced by little known Shandong Goldencell Electronics Technology http://www.goldencellbattery.com/, but even that is not guaranteed since RS can change the supplier at any time.
« Last Edit: December 06, 2021, 06:55:18 pm by wraper »
The following users thanked this post: ANTALIFE
  • Country: va
« Reply #3 on: December 06, 2021, 07:00:51 pm »
Ah, thanks! I missed the ESR...
