Author Topic: USB-C PD type cable. Suitable suppliers in Europe.  (Read 582 times)
Offline hp23Topic starter
« on: January 25, 2024, 12:06:29 pm »
Hi all, 1st post...
I have a product that is close to finalising, but I'm having trouble locating suitable cable. For background, this is a 14,000 lumen Flarm controlled unit for airborne conspicuity (in Europe, this is a GPS + 868MHz relative location device that signals the presence of other aircraft). The main unit employs a buck-boost converter for driving the LEDs (8 in total) at a 44Khz PWM. PWM peak current is approximately 6A, but the duty cycle and flash rate sees a wire rating of less than 3A. This needs to be connected to the LED flasher unit that is attached to the Glider plexiglass canopy.
I've been searching for a suitable cable to connect the main board that is screened & contains 2 x < 17AWG (>1.15mm2 diameter cables), with the other 3 being of smaller diameter (they are for 3v3 sensing and indicating functions). It would be ideal if the 2x<17AWG were independently screened. Yes, I have a heap of pre-compliance testing to do (shame that the EMC option on my DSA815-TG ran out…).
A number of suitable cables have emerged since the USB-PD standard came on the scene, but the usual suppliers (Digikey, Mouser, etc.) don’t seem to stock any. I’ve scoured the internet, including AliExpress to no avail.
Any thoughts?
Offline Veteran68
Re: USB-C PD type cable. Suitable suppliers in Europe.
« Reply #1 on: January 25, 2024, 03:37:57 pm »
So when you say "<17AWG" you mean bigger than 17AWG, i.e. 16AWG? You mention >1.15mm diameter so I assume that's what you mean.
That exact photo you posted is on the Amazon listing for the USB-C pigtails I bought. Have you tried these?
https://www.amazon.com/gp/product/B0B24WHS4H/
They're only 20AWG on the power lines but rated for 100W (20V@5A), which might be okay at a 6A peak, limited duty cycle. Nearly all other pigtail options I found were 22AWG for power. I don't know that I've seen a higher gauge than 20AWG in a USB C pigtail.
Another option of course would be to buy complete USB-C cables rated for >100W and cut off one end. You can find tons of USB-C cables rated for 240W, but hardly any mention actual conductor size so without testing a few, it would be a crapshoot.
And do you actually need the USB-C female end?
The following users thanked this post: hp23
« Reply #2 on: January 25, 2024, 05:23:23 pm »
Thanks, I'm starting to realise that this is my only option. As the PWM is typically 40% to 80% depending on the severity (LED's intensity increases as does the flashing freq.) This type of cable probably fits the bill best. It has no screen on it though & I am worried about the pre-compliance for CE. [EDIT: Has a screen, just seen the reviews section)
You're right AWG17 or bigger. AWG has always been a bit confusing as a standard.
This kind of leads me onto a second question. Break-away connectors. If the canopy is ejected mid flight, then the connector would need to gracefully separate. USB-C PD I imagine would be perfect for this application. I have never seen a USB-C connector used in a non-USB-C application & people don't read manuals. Would you take a chance on this?
« Last Edit: January 25, 2024, 05:29:52 pm by hp23 »
Offline TimNJ
« Reply #3 on: January 26, 2024, 04:15:07 am »
Tripp-Lite brand cable with USB-IF certification have been good upon evaluation. COM resistance is very low, probably like 15AWG equivalent, with an 18-20AWG VBUS conductor.
Offline TimNJ
« Reply #4 on: January 26, 2024, 05:11:25 pm »
I misremembered about the wire gauges.
Attached photo of Tripp Lite U040-C1M-C-5A. VBUS was ~24AWG, but  COM/GND conductors are probably 15-16AWG equivalent. Was still the lowest voltage drop of several cables tested. The shield/braid termination to the connector shell was also done quite well (crimped).
