Hey all, I need help finding dome coax adapters, but don't really know what to put into the search bar to get the right ones.
I have quite a few regular coax cables that would have been used with TV antennas, what I am looking for is an adapter from this "regular" sized coax to the small kind used with wireless PCI cards, that way I can take my server's wifi antenna outside the garage for better connection, and also get a USB wifi adapter and throw an antenna in the 12 foot satellite dish I got.
It seems I will need a female mini coax to male standard coax for connecting to the card, and then a male to male to connect from the large coax to the antenna's mini coax cable.
I think that I need male for the standard coax at least, not sure how you would specify male and female since the cable is what has the pin.
Anyways, what terms do I need to throw in to find the correct adapters?
