The inflow streamlines that i alluded to are streamlines of aether acceleration, not streamlines of velocity or speed.
How does acceleration towards a central point from every point on a sphere not increase something in the middle? It has to go somewhere, doesn'tduznt it? So there must presumably be streamlines of deceleration to match. Somewhere.
And... how can you have acceleration without a change in velocity or speed?
Yes, acceleration is a change in velocity or speed (i don’t see the problem here).
I said towards the center of the Earth, crudely put. The actual acceleration will of course be a combination of the acceleration of aether into the Sun, & Moon, etc. Teacher mistake-3 if u like.
U raise or infer some good points.
If the gravity at the center of Earth is zero (or somewhere near center), then the acceleration of the aetherwind near center must be zero. Yes.
If the acceleration of the aetherwind decreases somewhere inside Earth, then there must be a deceleration of the aetherwind, in which case gravity at the bottom of a deep hole might be upwards not downwards. No.
Aether is annihilated in matter, ie in Earth. Hence there is no need for a theoretical deceleration.
Once u pass a certain depth the acceleration will decrease, ie gravity decreases, & near center gravity is zero.
Aetherons that have been annihilated (in the photons inside Earth)(all matter is photons)(all photons are photons) no longer exist, hence they can't themselves accelerate or decelerate.
I admit that this process is not easy to imagine.
The inflow has to increase something in the middle. No.
If aether is annihilated then there is no buildup of anything near the center of the Earth.
Aether is a process, it is an excitation of the praether, the praether is the fundamental essence. The point here is that when a process is annihilated then nothing material is actually annihilated. If i stop juggling some oranges, then my juggling is not annihilated, it no longer exists. And no oranges have been harmed.
I said that nothing material has been annihilated. This wording is klumsy. I might come back & fix.
The acceleration of the aetherwind inside Earth will reach a max at some depth, & hence gravity will reach a max at that depth. Skoolkids of course all wrongly (today) think that gravity is a max at the surface (so did i).
