Author Topic: video: How to fix tech problems without a baseball bat  (Read 614 times)
Offline Ed.KloonkTopic starter
  • Cat video aficionado
« on: November 21, 2020, 12:10:04 pm »
He's saying that when the computer doesn't work, don't get angry, walk away and do something else while you think about what is wrong with the computer.
I say bah! Good old fashioned printer rage is cathartic. Nuts to him!
What do you think?
iratus parum formica
Offline Microdoser
Re: video: How to fix tech problems without a baseball bat
« Reply #1 on: November 21, 2020, 12:35:04 pm »
I often find the repair solution is heavily dependent on the budget.
If you have a large budget, take a bat to the thing and order a new one.
Medium budget, replace random parts until it works again.
Tiny budget, do an in-depth analysis, find out the actual problem. In most cases the problem is software related or user error, then remove the problem software and update your drivers to fix it then don't repeat whatever you did to cause the problem in the first place. If not, replace the only part that has failed.
