Hi folks,
I have recently added a lovely old device to my vintage collection. It is a Timer-Counter (Geiger Counter) made by Watson-Victor LTD, in what I assume to be the 50's/60's.
After some initial inspection and measurements, I brought it up carefully on my variac and was delighted to see that it worked perfectly.
I set to reverse engineering the circuit, taking multiple measurements along the way, with the firm assumption that all of those old electrolytic's would be dry and in need of replacement.
this is where it got interesting, and I ended up with a growing list of questions that I would love some expert guidance on.
The circuit is driven by two Toshiba 12AT7 and one 12AU7A valves. From what I can initially tell, one of the 12AT7's is for amplifying the audio crackles and the other for amplifying the output from the detector tube. I have not fully investigated the function of the low gain 12AU7A in the middle yet.
The front of the device includes three decade counters, that are using Okaya Musen DK24 Deketron counting tubes. These wonderful things are the first I have ever seen in person, and their operation is fascinating to me.
Where I need help:
The power transformer, is an A&R 6069, that has a primary winding arrangement that I have not see before. I have been unable to find any documentation on the 6069 transformer unfortunately to better explain it.
- the primary has the normal 240v black and red wires, and it also includes a single green wire. I initially assumed that this was some kind of primary winding tap, but it is not. The green wire is open circuit from any other wire on the transformer (both primary and secondary) and is NOT connected internally to the transformer chassis. This had me puzzled, especially after I saw that when it connected to the PSU board, it immediatly joined to one lead of that I assume is the secondary heater filament winding. I didnt even know how to draw this on my circuit diagram, until I found an ancient schematic for a circuit using an A&R 5776, which showed the green wire like a dashed line next to the transformer core. I am assuming this is the same as what my 6069 has?
- - can anyone tell me what that primary wire is called, and why this power transformer specifically depicts the connection to chassis, and to one wire of the secondary, like this?
The rectification part of the circuit uses two ancient "Top Hat" style diodes that are made by Toshiba and have a part number of 1S94v. I can't find any datasheet for these either. They measure reasonably for silicon at 0.5v and 0.52v.
- I am not sure if it is just the way that I have laid out my schematic as i traced and measured the circuit, but I am unfamiliar with the topology of the rectification stage, and frankly, even the way to reference voltage measurements through the circuit... for the sake of consistency, all measurements I made, are with respect to the earth/chassis. (green wire)
So far, most of the values are measuring ok, and the system operates. Other than the poor dual-electrolytic where one of its 16uF 500V halves, has 565v across it. I will need to get that under control before i pop it. the Cap itself is measuring 17uF on both sides, which is far better than i would have anticipated!
I have not had the time to reverse engineer and draw the schematic of the main board yet, as I would like to get the PSU voltages all corrected first, so that I dont skew my measurements.
I would love to hear thoughts on the transformer, the diodes and the circuit design in general, as it is a bit of a mystery to me so far and I cant find any service manual or technical documentation on the device at all. it is called "Counter-Timer" "Model-4DSPT10".
Thanks In Advance,
Floyd
