Author Topic: vintage soviet resistor  (Read 3952 times)
Offline vasi_roTopic starter
« on: November 07, 2016, 04:19:45 pm »
I found some vintage wirewound resistor. I cant find any info of this model on Google ...  maybe a russian speaking user can find or have more info ?
Any idee for a project with these ? I only have 9.2K value
Offline DmitryL
Re: vintage soviet resistor
« Reply #1 on: November 07, 2016, 05:04:40 pm »
Here are the specs, just use some web translator..
http://niiemp.ru/produktsiya-i-uslugi/provolochnye-metallofolgovye-kermetnye-rezistory-i-nr/provolochnye/item/c5-53-c5-54.html
It seems to have about 5ppm per degree C temp co.
If you connect all of them in parallel you can make a nice heater :)
Offline Ampera
    • Ampera's Forums
« Reply #2 on: November 07, 2016, 05:20:29 pm »
9.2kohm, +/- 0.05 50 volts max
seems to even have a datecode, maybe 1954, January?
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Online wraper
  • Country: lv
« Reply #3 on: November 07, 2016, 05:59:26 pm »
No, date code is April 1989.
Offline MosherIV
« Reply #4 on: November 07, 2016, 06:08:55 pm »
Precision voltage divider. Put 10 across a precision voltage reference device eg REF01 - you can get 10V to 0V in precise 1V increments.
The following users thanked this post: 3db
Offline Gyro
« Reply #5 on: November 07, 2016, 09:34:36 pm »
Even better, build an even more accurate 10:1 Hamon divider with them.
Best Regards, Chris
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #6 on: November 07, 2016, 11:43:30 pm »
Here is a scan of the datasheet: http://www.155la3.ru/datafiles/s5_53_54_60_tu_1983.pdf
Untranslated, naturally, but the numbers are numbers.
TL;DR: These are precision resistors, in all-climate package (on the order of 10^-6 temperature coefficient within -60 to +125*C range), made in the 80s.
Nothing else sound special about them.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #7 on: November 08, 2016, 04:53:55 pm »
Wire wound 9.2kohm +/-0.05%, 1W, 50ppm/C max. tempco, made 04/1989 .
Cheers
Alex
Offline bitwelder
« Reply #8 on: November 09, 2016, 06:21:55 am »
What's the stability over time of such type of resistors (considering that they are 27 years old?)
Offline Zero999
  • 0999
« Reply #9 on: November 09, 2016, 11:40:21 am »
Their stability will be much better than brand new resistors, although the actual values may have already drifted further from the rated values.
Offline batteksystem
  • Country: hk
    • My ebay store
« Reply #10 on: November 09, 2016, 12:07:24 pm »
I see there are 2 variants, ??????? ???? ? ??????? ???, the difference is only about the dimension though. However, the electrical properties should be the same.
