General => General Technical Chat => Topic started by: Psi on November 18, 2017, 10:35:49 am
So im looking for a ultra tiny bluetooth PCB antenna design.
Something that can fit in around a 5mm x 5mm (0.2inch) square.
It can be a fractal antenna or a weird geometry and it really doesn't have to perform amazing.
I wouldnt expect it to, being so small.
Anyone have ideas or known working designs?
Maybe the little ceramic antennaes?
http://uk.farnell.com/taiyo-yuden/ah316m245001-t/antenna-bluetooth-w-lan-zigbee/dp/2084742?antenna-type=multilayer&pf=110323808&anyFilterApplied=true&ddkey=http%3Aen-GB%2FElement14_United_Kingdom%2Fc%2Fsecurity-audio-visual%2Faerials-aerials-management (http://uk.farnell.com/taiyo-yuden/ah316m245001-t/antenna-bluetooth-w-lan-zigbee/dp/2084742?antenna-type=multilayer&pf=110323808&anyFilterApplied=true&ddkey=http%3Aen-GB%2FElement14_United_Kingdom%2Fc%2Fsecurity-audio-visual%2Faerials-aerials-management)
edit: or these fellows:
http://uk.farnell.com/molex/47948-0001/antenna-2-4ghz-on-ground-smd/dp/1961265 (http://uk.farnell.com/molex/47948-0001/antenna-2-4ghz-on-ground-smd/dp/1961265)
Needs to be a PCB antenna, for cost
