when is it Ok to mix water with electronics?
have this
philips 170B pc lcd monitor I found abandoned in the street, but as it was raining at the time.
the PC monitor was soaking wet, believing it to be only good for scraping , I did put it aside at home for a month.
to dry out, then just a day before I was about to start scraping it for copper, I did a test just to see if it would work or go Pop!
to my surprise it still worked, so I left it running on the bench for 24hrs just to see if it would give up the magic smoke,
but it did not.
just this week I seen another video that had something about water & electronics
here is two videos, one is the 8 bit guy washing a V20 pcb and the other is Techmoan and about
air compressors been bad for cleaning electronics as that may have water droplets in the air
I have always believed water & electronics do not mix, so its there something I am missing here?
is there an exception to the rule?
Restoration - The Worst VIC-20 I've ever seen - Part 1 8 bit guy youtube.
at 15:12 he uses water on the pcb.
rinse it off with the hose! that is a garden hose on electronics.
PCB DUST-OFF Ryobi mini compressor vs Compu-Cleaner Xpert Techmoan youtube.
at 15:11 to 15:45
