Author Topic: Server Error Reports  (Read 779737 times)
Offline gnifTopic starter
  • Views and opinions are my own
    • AMD
Re: Server Error Reports
« Reply #700 on: January 13, 2024, 12:28:34 am »
The major work has been completed but the site will still have some slowness while I remove the old now deprecated gluster storage. Once this is completed we should be back to normal, but faster ;)
Edit: work has been completed, there should not be any more interruptions to services.
« Last Edit: January 13, 2024, 12:49:55 am by gnif »
The following users thanked this post: EEVblog, PA0PBZ, kjpye, PlainName, Andy Watson, Kean, HwAoRrDk, Nominal Animal, pcprogrammer
    • AMD
« Reply #701 on: February 06, 2024, 04:36:59 am »
Heading this off before people report it. There was an unexpected power interruption at the Data Centre that brought the servers down that are hosting this website. Things are fully back online, and we are seeking information from the DC as to what the reason for the outage was.
The following users thanked this post: EEVblog, Ed.Kloonk, SeanB, Kean
    • AMD
« Reply #702 on: February 06, 2024, 09:53:50 am »
Just a heads up.
In the next 30 minutes or so there will be some disruptions while issues from the outage today are rectified. I will as always, post here when this work is complete.
Edit: Still in progress. sorry for the long outage, we are still having issues with data consistency across the cluster. We had the failed drive replaced and the fault moved to another disk, so we have been carefully bringing things back into a consistent state before allowing the DC to mess around with things futher.
« Last Edit: February 06, 2024, 04:53:49 pm by gnif »
Offline ifrythings
« Reply #703 on: February 06, 2024, 05:11:18 pm »
Just a heads up.
Would this cause the 502 bad gateway error and random “file not found” error that will load after several refreshes?
    • AMD
« Reply #704 on: February 06, 2024, 05:13:45 pm »
Yes, one of the servers in the cluster was having issues with accessing content on the disk.
The following users thanked this post: The Soulman, Nominal Animal
    • AMD
« Reply #705 on: February 07, 2024, 02:49:26 am »
Services have returned to normal.
The following users thanked this post: EEVblog, IanB, xrunner, Kean
    • AMD
« Reply #706 on: April 22, 2024, 01:29:53 am »
Seems there was some kind of outage at the data center again, both of our servers were rebooted. Services are back online, but may be a bit slow while the servers caches warm back up.
The following users thanked this post: EEVblog, Kean, Brumby, MK14
