Author Topic: Server Error Reports  (Read 220307 times)
Offline amyk
Re: Server Error Reports
« Reply #250 on: July 12, 2020, 03:23:37 am »
I just experienced this image bug with two posts here:
https://www.eevblog.com/forum/repair/old-cnc-machine-memory-board/
The image URLs are:
https://www.eevblog.com/forum/repair/old-cnc-machine-memory-board/?action=dlattach;attach=1021664;image
https://www.eevblog.com/forum/repair/old-cnc-machine-memory-board/?action=dlattach;attach=1021660;image
Note that they are different, but the contents are exactly the same.
HTTP headers of the two for comparison:
HTTP/1.1 200 OK
Server: nginx
Date: Sun, 12 Jul 2020 03:18:39 GMT
Content-Type: image/jpeg
Transfer-Encoding: chunked
Connection: keep-alive
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1
X-Content-Type-Options: nosniff
Content-Encoding: none
Pragma:
Content-Transfer-Encoding: binary
Expires: Mon, 12 Jul 2021 03:18:39 GMT
Last-Modified: Sun, 12 Jul 2020 01:40:14 GMT
Accept-Ranges: bytes
ETag: "10216643-711-2615G.jpg1594518014"
Content-Disposition: inline; filename="3-711-2615G.jpg"
Cache-Control: max-age=31536000, private
X-Backend: web1.eevblog.com
HTTP/1.1 200 OK
Server: nginx
Date: Sun, 12 Jul 2020 03:18:53 GMT
X-XSS-Protection: 1
Pragma:
Expires: Mon, 12 Jul 2021 03:18:53 GMT
ETag: "10216603 542 1174A.JPG1594518014"
Content-Disposition: inline; filename="3 542 1174A.JPG"
X-Backend: web2.eevblog.com
It claims the filenames are different but the last-modified for the two are the same, as-is the timestamp-ish part of the ETag (which translates precisely to the last-modified.)
Offline PushUp
Re: Server Error Reports "Thread-Problems with uploaded attachements!"
« Reply #251 on: July 12, 2020, 08:28:40 am »
As mentioned by TV84, this might be a big problem:
https://www.eevblog.com/forum/testgear/new-rigol-16-bit-function-generators-dg800900-series/msg3122658/#msg3122658
As long as only pictrures are concerned, it is simply annoying, compared to the effort you had with making, downsizing (to meet the max. 5MB limit) and last but not least uploading the images to your post.
The problem:
The Thumbnail-Picture is still fine, but the link to it is wrong and leads to a completely false picture. It is somehow messed up with any (!!!) further reply you make in the forum, I guess?!
Here is an example:
https://www.eevblog.com/forum/testgear/uni-t-ut181a-triplett-9065-trend-viewer-question/msg3132148/#msg3132148
The thumbnail of the first pic is correct, but it leads to the picture from my next reply, therefore it was somehow replaced by it, which leads to a mess, as described pictures are gone and the message gets useless...
Probably, it is better to use external image/file hoster, till the problem is solved to avoid a total mess?!
Cheers!
Due to the massive "EEVblog forum attachement bug", I am now using an external picture hoster, till it is solved...
Offline SilverSolder
« Reply #252 on: July 12, 2020, 11:19:54 am »
I wonder why some people get less problems...
One thing that might vary from user to user, is how the files are named.   Do you always give the image a unique name in every post (including, being unique across all posts)?
Offline dcac
« Reply #253 on: July 12, 2020, 11:36:22 am »
When I post multiple pics they are usually from the same folder and therefor also has a unique name.
I wonder if the problem is more related to the amount of server traffic when you post the pictures/attachments.
Offline dcac
« Reply #254 on: July 12, 2020, 11:39:12 am »
This is the 'element code' of my two mentioned posts/pics from a PC that opens same image from both - or shows the error.
When I get access to the PC I made those post from I do the same thing to see if any difference appear.
<a href="https://www.eevblog.com/forum/projects/show-us-your-mains-waveform!/?action=dlattach;attach=1021018;image" id="link_1021018-0" onclick="return ILAexpandThumb(1021018-0);"><img src="https://www.eevblog.com/forum/index.php?action=dlattach;topic=240210.0;attach=1021020;image" alt="1021018-0" title="Show us your mains waveform!" id="thumb_1021018-0" style="width:100px;border:0;" data-pagespeed-url-hash="2538578502" onload="pagespeed.CriticalImages.checkImageForCriticality(this);"></a>
<a href="https://www.eevblog.com/forum/projects/show-us-your-mains-waveform!/?action=dlattach;attach=1021014;image" id="link_1021014-0" onclick="return ILAexpandThumb(1021014-0);"><img src="https://www.eevblog.com/forum/index.php?action=dlattach;topic=240210.0;attach=1021016;image" alt="1021014-0" title="Show us your mains waveform!" id="thumb_1021014-0" style="width:100px;border:0;" data-pagespeed-url-hash="1545177425" onload="pagespeed.CriticalImages.checkImageForCriticality(this);"></a>
EDIT: well the code is exactly the same from the PC that can open correct image - no big surprise there but I'm still puzzled how it manage to fetch the correct image it does not seem to get it from Firefox cache.
EDIT2: so what I am essentially observing is this link:
will open correct image from the PC I posted/uploaded it from and show a sine wave in blue. But if I open it from any other PC it opens the image from my previous post and show a sine wave in red.
All thumbnails are shown correctly from all PC I've tested.
« Last Edit: July 12, 2020, 02:50:33 pm by dcac »
« Reply #255 on: July 12, 2020, 12:17:07 pm »
When I hit those two links (the img src links) from here, they are definitely different thumbnails.
The following users thanked this post: dcac
Offline rhb
« Reply #256 on: July 12, 2020, 01:04:40 pm »
I think it affects all attachments.  IIRC I had an Octave script that got posted as a jpg which I deleted when I couldn't open the image.
Reg
Offline amyk
« Reply #257 on: July 13, 2020, 01:46:03 am »
From that link I am seeing a red sine wave.
Note: you should be able to do ctrl+F5 to force a reload from network and not cache, in most browsers. You can also directly access the network, with guarantee of no caching, by using utility like wget or curl.
Offline dcac
« Reply #258 on: July 13, 2020, 01:55:16 pm »
Yeah I finally manage to clear the Firefox cache - though I had to clear it restart FF and then clear it again. Now the posting PC also fetches the wrong image which is the red sine wave. I didn't clear any cookies so these probably had no effect on this problem.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #259 on: July 14, 2020, 06:24:33 am »
Also, can we have some way to disable Imgur embeds?
Say I post a link, a raw URL, not an img embed, and that's literally all I want.
There exists no combination of Imgur URL (gallery or direct link) that won't auto embed.  It's way too greedy.
Often I want to refer to links inline with text and this BIG MOTHERFUCKING EMBED interrupts my text, it's ridiculous.
YouTube embeds do the same thing, but there at least you can use a shortened link to evade it (IIRC?).
Seven Transistor Labs, LLC
Offline BrianHG
« Reply #260 on: July 15, 2020, 09:37:24 pm »
Image files and attached files corruptions going MAD.....
Example, 3 corrupt images on this thread page:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg3135492/#msg3135492
Scroll down, the errors are over a few posts...
Try expanding the timing diagram in this post:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg3121924/#msg3121924
try expanding the second image in this post:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg3111866/#msg3111866
Or this one:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg3111884/#msg3111884
This one has the wrong image:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/1075/
This one is also corrupt:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg3107130/#msg3107130
The top example now has 4 corrupt images.  Yes, 1 new one in the time I've been writing this message if you go to the first link and scroll up instead of down.  Those images were there fine yesterday.
Here is another one:
https://www.eevblog.com/forum/fpga/home-made-systemverilog-3-word-zero-latency-fifo-documented-for-beginners/msg3123336/#msg3123336
In fact, over the last week, I've editing my posts, deleting & re-uploading images again & again.
Does anyone know what's been going on?
__________
BrianHG.
Offline amyk
« Reply #261 on: July 16, 2020, 01:26:16 pm »
Quote my post or click this link to find out how to get around that. ;)
Offline tooki
« Reply #262 on: July 18, 2020, 04:04:34 pm »
People! It’s a known issue, and it’s got nothing to do with your browser cache or anything, as it’s purely a server database problem. It seems to be triggered by interrupted posting.
Yes.
See what the server admin has said, starting here: https://www.eevblog.com/forum/chat/website-error-reports/msg3107598/#msg3107598
The following users thanked this post: amyk
Online mnementh
  • *Escaping The Suck*
« Reply #263 on: July 23, 2020, 03:19:56 am »
A fellow eevBlog member has suggested a possible workaround:
I think there's a problem only with the first attachment slot. If you skip the first one and use the other one it appear to be working fine.
I'm going to try this for a few days and see if it makes any difference.
Cheers,
« Last Edit: July 23, 2020, 03:21:39 am by mnementh »
Online mnementh
« Reply #264 on: July 24, 2020, 04:01:14 pm »
Update: So far, this method seems to be working. Even survives being interrupted by "There has been a new post" warning and a 4.1MB .pdf.
Will followup again in a day or three.
 :popcorn:
Offline dcac
« Reply #265 on: July 25, 2020, 12:21:09 pm »
I'm getting 404 error trying to access this thread:
https://www.eevblog.com/forum/testgear/eevblog-121gw-multimeter-issues
Offline joeqsmith
« Reply #266 on: July 25, 2020, 03:41:13 pm »
Obviously the photo links continues to not work.   I tried to delete a picture that was inserted in one post but was being referenced in another.  This had no effect.  So I blew away the entire post which also had no effect.
I'm not sure if they keep metrics on who posts the most pictures but I suspect I abuse it far more than most.   I wonder if I were to start deleting my old posts/images would it help ease the problem?   If so, just let me know and I will start cleaning up my mess.
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline StillTrying
  • Country: Broken Britain
« Reply #267 on: July 25, 2020, 04:21:45 pm »
I post nothing compared to others but still see the errors.
Post 2 of everything then a few hours later delete the spare or faulty versions. :-/O  :)
« Last Edit: July 25, 2020, 04:23:58 pm by StillTrying »
CML+  That took much longer than I thought it would.
Offline joeqsmith
« Reply #268 on: July 25, 2020, 04:30:32 pm »
I was thinking that it's overall just too much data for the software to handle.    Looking at my attachments, there's 121 pages of 25 images/page or over 3000 images spanning 5 years.   That's a lot of images.
Online mnementh
« Reply #269 on: July 25, 2020, 06:21:34 pm »
FWIW: This workaround is still working for me.
*knocks on wood*
Online Monkeh
« Reply #270 on: July 25, 2020, 06:26:28 pm »
That's a really, really small number of files.
It seems more like a database replication issue.
Offline joeqsmith
« Reply #271 on: July 25, 2020, 07:26:55 pm »
I cleaned up most of what I consider my worthless posts.   I would need to take down some of my larger threads to really make a dent in it but even if I cleaned everything out,  I don't see it helping with this particular problem.
Online mnementh
« Reply #272 on: July 25, 2020, 11:27:40 pm »
This is the latest I know of from gnif when he was available to work on the problem:
...I usually use Firefox on my PCs; I brought up the thread on my iPad/Firefox and still FUBAR the same way, so not a local cache issue. Same behavior in Edge.
This may be related to another bug that has been happening for months; when posting multiple images, IF the posting process is interrupted for a new post warning, the damned thing just forgets the first pic. It attaches the rest of the pics normally, but that first one you ALWAYS have to go back and attach again...  [edited for brevity]
Déjà vu: Best enjoyed as a garnish with wine, cheese and baguettes.
SMF doesn't care about the filename, it stores all attachments as a hash of the file contents and references them via a table. There are two possible reasons why this happened:
1) The bug you mentioned
2) The maintenance last night was intended to correct some sync issues between the web servers as the database cluster had lost sync. Normally this would be fine, but there were other factors at play at the same time that prevented them from determining who was the "latest" and both were accepting update/insert queries at the same time (split-brain).
I should have been clearer I am sorry, if this is seen on new posts as of today, please let me know. Feel free to fix any that are messed up from prior.
Since then it has been off & on, though server loading does affect it. It def happens a lot more often on weekends.
 :popcorn:
Online mnementh
« Reply #273 on: July 27, 2020, 01:55:51 pm »
This workaround is still working for me. Last night I posted a mini how-to with 10 pics; deliberately did not wait for all the pics and just hit [POST]. eevBlog gagged on it for a few seconds, then popped up a THERE HAS BEEN A NEW POST warning. But after I clicked [POST] again, all the pics came up without issue; they were even in the right order for a change.
 :popcorn:
Offline tooki
« Reply #274 on: July 27, 2020, 09:11:14 pm »
OK, so here's another data point for you, Gnif!
I just posted a thread reply with an inline image attachment. I didn't pay attention to whether the attachment icon showed up on the post before going in to modify the post. After saving the modified post, I noticed that while the inline image still appears properly, it shows no attachment icon, and clicking on Modify again also shows no attachment to remove!! (I've verified that in another pre-bug post with inline attachments, they still show up as attachments in the Modify screen.)
