I don't know if this is the proper section of the forum, but the context is very unusual and informal, like a chat.
Yesterday my colleague was testing four ad620 units bought on eBay because found for cheap. Farnel lists a single chip for about 10 euro (plus postage), on eBay four units were purchased for 25 euro including postage.
The AD620 is a high accuracy instrumentation amplifier that requires only one external resistor to set gains of 1 to 10000.
Datasheet of AD620 says that this resistance (called Rg) must be calculated like this:
Rg = 49.4 kOhm/(G-1)
G = gain
As far as I see from his breadboard, he used 47 Ohm resistor, so gain is about 1000. Reference voltage is 0V, there is a single power supply 5V, and shorted V- V+ to the ground through a couple of 10K resistors.
Results? He said two chip units are damaged by these experiment, but I don't see why
I have here a working circuit that uses a ad620 unit to measure the output of "KMZ10B magnetoresistive" sensor, which has a Wheatstone bridge. In this case the reference voltage is about 2.5V.
I removed my ad620 (which works) and tested the two chips used by my colleague: and booom! It's true, those two tested chips really don't work! Their Vout doesn't move from 3.8V, so probably there is a damaged input section or something.
But remember? He has four chips, and it's more interesting that the other two untested chips do work!
Seriously I don't know if and how his testing could damage a chip.
