Author Topic: Well LTspice has gone to crap now AD have got it...  (Read 5022 times)
Offline bd139Topic starter
« on: May 17, 2018, 09:49:01 am »
So I just got myself a new workstation box today and installed the latest AD branded LTspice drop.
Literally everything I do crashes it. It hard locks, never responds and that's it. This, over and over again:
Not talking a complex circuit as well. Just a simple diff amp:
Fucks sake AD!
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
Re: Well LTspice has gone to crap now AD have got it...
« Reply #1 on: May 17, 2018, 10:16:01 am »
I don't know about you but it works fine with me.
Offline JPortici
« Reply #2 on: May 17, 2018, 10:27:02 am »
LTSPICE XVII was released before the AD acquisition i think?
it works for me anyway on my windows 10 machine
One thing, i have to disable the reatrded admin policy, because software has to be launched as an admin to do things like create or edit symbols
« Reply #3 on: May 17, 2018, 10:41:03 am »
This is the version I have:
Still can't get it to do anything. This is on Windows 10 1803. Hardware is good. It ran memtest86 soak for 48 hours and is an ECC equipped workstation class machine.
Solved it the old fashioned way. Bob Pease was right but for the wrong reasons...
Offline Zero999
  • 0999
« Reply #4 on: May 17, 2018, 11:10:36 am »
Try the 32-bit version.
By the way, the older version is still available.
« Reply #5 on: May 17, 2018, 11:20:10 am »
Will try both of those in turn and see what happens. Good idea.  :-+
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #6 on: May 17, 2018, 01:14:17 pm »
Hello!
Same 64 bit version (4th May 2018) runs fine in a Win7 VM and under wine 3.0. I didn't have any problems yet.
Offline Bassman59
  • Yes, I do this for a living
« Reply #7 on: May 17, 2018, 06:22:54 pm »
Hello!
the problem might well be his Windows 10. I too run LTSpice XVII (or whatever it's called!) on a Win7 VM.
I don't know what's different about the new version than the previous LTSpice that also ran on macOS.
« Reply #8 on: May 17, 2018, 06:41:00 pm »
Tried it on a non 1803 machine and it works. Hmm.
Offline RobK_NL
« Reply #9 on: May 17, 2018, 08:03:32 pm »
I got this message from my CAD software supplier yesterday:
"Due to a problem caused by Microsoft with the recent Windows 10 update version 1803, CADSTAR software might stop working when being authorised on a dongle. We advise customers NOT to install this Windows update."
So, yeah, well done Microsoft.  :palm:
Tell us what problem you want to solve, not what solution you're having problems with
Offline VEGETA
  • Country: jo
    • Thundertronics
« Reply #10 on: May 17, 2018, 08:04:42 pm »
BTW I see new stuff in this version like a model for heatsink and other weird stuff. What are the new major additions since AD took over?
I suspect that they will change its name if they put more effort into it.
« Reply #11 on: May 17, 2018, 08:11:39 pm »
Yep looks like MSFT fail. Fucks sake.
No idea yet. Keeps crashing! :)
Did the design by hand and built it in the end. Got two oscillators, attenuator, balances mixer and two filters working without LTspice in the end.
Offline palpurul
  • Country: tr
  • Hey
« Reply #12 on: May 17, 2018, 08:38:25 pm »
I use LTSpice regularly. It works fine. Wierd  :wtf:. I am using windows 8.1. I was going to upgrade to windows 10, now I hesitate.
Offline VEGETA
  • Country: jo
    • Thundertronics
« Reply #13 on: May 17, 2018, 08:40:43 pm »
I use it on latest windows 10 update with 0 problems before and after.
« Reply #14 on: May 17, 2018, 08:53:55 pm »
What LTspice version are you using and is it 32 or 64 bit?
Got a real problem now. Can’t uninstall the old version as it has its own installer rather than MSI and that crashes. Grr.
Offline rdl
« Reply #15 on: May 17, 2018, 09:04:47 pm »
Look and see if a restore point was made as part of or just before the install process.
« Reply #16 on: May 17, 2018, 09:17:25 pm »
This was a fresh build of 1803 on a new machine.  No system restore.
Offline newbrain
« Reply #17 on: May 17, 2018, 09:55:35 pm »
Same here, no problems, see picture.
You could try adding your user with write rights to the ACL of the topmost directory of the subtree where symbols are stored.
Start an administrator PowerShell or cmd window, change to the parent directory of the one you want to modify and issue:
icacls.exe 'dirname' /grant JPortici:F /T
You should then be able to create/change/delete files and folders (F==full control) under that subtree.
The same can be done with about a zillion clicks from the Security tab in Properties panel of the directory.
Offline Mr. Scram
  • Display aficionado
« Reply #18 on: May 17, 2018, 10:08:37 pm »
1803 seems to have some issues right now. I love rolling updates, it's the same problems you have with a proper migration only now at least once a year.  :palm:
« Reply #19 on: May 17, 2018, 10:17:36 pm »
Exactly that.
I’m rolling xubuntu out now and will run it in a VM on windows 7.
Offline JPortici
« Reply #20 on: May 18, 2018, 05:52:49 am »
Ah, makes sense. The only big update i had installed was last year's creators update. Fall creators brought in a lot of issues so they were disabled.
Offline Mr. Scram
« Reply #21 on: May 18, 2018, 08:18:35 am »
1803 is yet another update. 1709 is the fall creator's you mention.
Offline Masa
« Reply #22 on: May 18, 2018, 03:22:56 pm »
Older version of XVII works fine here on Win10 1803 too.
