Author Topic: Well, that's one way to make contact  (Read 3726 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: May 26, 2015, 01:29:20 pm »
Found this on facebook, had to share...
Offline c4757p
  • adieu
Re: Well, that's one way to make contact
« Reply #1 on: May 26, 2015, 01:36:34 pm »
That's disturbing. Should have been tagged NSFW.
Offline Seekonk
« Reply #2 on: May 26, 2015, 02:20:46 pm »
Always put the tywrap through the bolt hole.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: May 26, 2015, 05:12:32 pm »
I always use three cable ties per cable! One is very unprofessional :--
Offline zapta
« Reply #4 on: May 26, 2015, 05:22:53 pm »
Is it a permanent setup or just an intermediate step during installation?
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: May 26, 2015, 05:23:17 pm »
Hey, at least his cable ties are properly grounded ! they have the required green yellow tape on em !
« Reply #6 on: May 26, 2015, 05:26:25 pm »
I am going to guess that was only for a low power test. Then they would terminate the cables properly after getting them through the gland during installation.
Offline Seekonk
« Reply #7 on: May 26, 2015, 05:45:11 pm »
Maybe pulling on that yellow/green tape is the quick disconnect.
Offline bitwelder
« Reply #8 on: May 26, 2015, 06:08:11 pm »
I guess that before the current reaches 160A the cable tie will give up and 'protect' the fuse...
« Reply #9 on: May 26, 2015, 06:23:18 pm »
If you think that is scary look at the cable used to earth the overvoltage protection, and the cable used to connect it. 160A fuse, and then a VDR and spark gap unit not capable of opening a 160A fuse safely, with a connecting wire for both phase and protective earth that will very likely fuse open ( with the attendant copper vapour spraying all over the cabinet) before the current is high enough and present long enough to blow open the motor inrush rated fuse link.
I have seen those fuse links running at 200A continuous, and they might fail only after a decade of that in industrial units. The 200A fuse at the 500kVA minisub at work took 50 years of peaking at 250A ( I measured it one evening with peak residential cooking load applied) before 2 finally soft failed.
Offline retrolefty
« Reply #10 on: May 26, 2015, 06:57:23 pm »
 My thought also. Possibly testing for desired phase rotation before proper permanent termination?
Offline electr_peter
  • Country: lt
« Reply #11 on: May 26, 2015, 07:56:08 pm »
I can add few points to discussion:
  • (see *) Person doing that installation is not professional electrician or EE of any sort. More likely plumber/janitor/office clerk/any profession not related to electricity
  • reliable (low or high power) electrical connections are almost impossible task without specialised set of tools
  • cable ties are universal tool for everything, especially for quick temporary fixes. Oh, what a satire, installation above is temporary by all means :-DD
To prove last point about cable ties, see a photo of a big poster in a city. It took one glance from 100 m to tell that something is not up to standard. Can you tell what is not right?
EDIT: (*) Looking second time at the image in the first post, I have to say I am leaning to opinion of SeanB. Installation is done very neatly, cables are cut and cable wrapped very precisely. Additionally, yellow/green duct tape is wrapped around the cable ties. Picture seems to indicate that electrician is doing some preliminary checks and markings (for internal use only).
« Last Edit: May 28, 2015, 06:01:33 pm by electr_peter »
