Author Topic: WiFi boosters 1W or 2W or modern 2W comparison!!  (Read 16442 times)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: WiFi boosters 1W or 2W or modern 2W comparison!!
« Reply #25 on: December 09, 2011, 09:35:08 pm »
with lots souls as engine
there's the problem they cannot get 100% rating. miscommunication between receptionist and packing man will result wrong item being sent. hope it will not happen to you :P
Offline sonicj
  • updata successed!
« Reply #26 on: December 09, 2011, 09:48:04 pm »
12 Years experience with FM - VHF - CB, is always gain.  :)
VHF is very different from microwave....  have you tried it without the dish??  did you tune it after adding the dish? that antenna already has a reflector... (the final element)  i have a feeling that dish is pumping the side lobes somewhere they shouldn't be going.
you should have no problem getting a reliable 1km point to point link with a pair of yagis & decent unamplified routers .
-sj (wd4awb)
« Last Edit: December 09, 2011, 09:50:31 pm by sonicj »
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #27 on: December 09, 2011, 10:14:16 pm »
The dish works as shield from the 30 routers at my back, and 10 routers at my side.
And so I have just 20 routers at the front.
Multiply all those sources as noise, and you will find out why I have come to this solution.
  • Country: gr
  • User is banned.
« Reply #28 on: December 09, 2011, 10:17:09 pm »
Nahh Nina loves me very much so to let this happen.  :P
« Last Edit: December 09, 2011, 10:19:08 pm by Kiriakos-GR »
