Author Topic: What are these called?  (Read 1585 times)
Offline TerraHertzTopic starter
    • It's not really a Blog
« on: July 26, 2016, 01:43:33 pm »
See pic. Darnit, I thought these were called cotter pins, but ebay and Wiki use the term cotter pin to describe what I've always called split pins.
I need the right word, to find some longer ones of these online. Split pins won't do. Has to be these, which are springy hard steel that you press into a slightly under size hole.
This is for securing the head of a medium size sledge hammer.
Offline R_Gtx
Re: What are these called?
« Reply #1 on: July 26, 2016, 01:48:05 pm »
Tension pins or roll pins
The following users thanked this post: TerraHertz
« Reply #2 on: July 26, 2016, 02:08:31 pm »
Ah ha. The magic google word. Tension pin,  spring, roll or C pins. Thanks.
Edit: This is for that rock removal project I mentioned in https://www.eevblog.com/forum/chat/what-did-you-buy-today-post-your-latest-purchase!/msg929403/#msg929403
It's going well, faster than I expected.
First pic is original rocks; red line all that's left now. (A bit after the last pic below.)
Two or three more trips, and then I'll have the job of moving all the rubble. Whoopee.
« Last Edit: July 26, 2016, 02:57:39 pm by TerraHertz »
Offline GEuser
  • Is Leaving
« Reply #3 on: July 27, 2016, 07:42:14 am »
Always know as a Roll pin my way , cotter pins also were split pins .
As you now have found out ..
Soon
