A lot of the stuff I find myself doing at the moment is just little odd jobs here and there; not exactly worthy of a separate thread. Thought I'd dig this one up instead of starting a new one...
Recently, I had the HDMI port on a Dell laptop break... again. The first laptop had the pins separate from the middle plastic section after a dozen or so uses. The second had the middle section fracture in a similar time-frame like so:
Dell warranty is useless in this regard, and they wanted $900 or so to repair it, so I thought I'd give it a go (on the 2nd laptop). The connector is some weirdo mid-plane through-hole jobbie that I couldn't find anywhere, so I ended up getting a spare motherboard from the UK and did a transplant.
A hot air rework gun and a bit of hair pulling later, and I now have one working (if slightly melted) HDMI port again.
What I just finished up now is rebuilding the guts of a guitar distortion pedal I made about 10 years ago. It was a bit noisy (not in the good way), and I figured the rat's nest within could use a cleanup. I also added indicator lights for the bypass and boost switches. This is partway through:
The finished 'product' (yes, the labelling is the epitome of fine calligraphy). Testing to happen when it's not 3:30am...
