I have a VT-51 Megaphone (rectangle-shape) that does not work. When opening the battery compartment there are two 2SB337 power transistors sitting atop the inside casing. Googling them, they appear to be germanium.
Should I suspect them as the problem, or some other cause?
The megaphone is dead as a doornail. When germanium transistors fail or are failing, what are the symptoms?
I also have a large, portable "all transistor" Zenith shortwave radio. It is germanium, and has a positive ground?
Thank you.
Sincerely,
IM
