Author Topic: what connector is this ?  (Read 767 times)
Offline simondid
« on: February 23, 2019, 02:56:47 pm »
hey
sry if im in the wrong category if pleas move the post
so I'm looking for an extension cable for a microphone the microphone is made with a wired connector which I don't know the name of so I was hoping someone could help me find a name or a place to buy an extension cable or the connector separate
see images below ore on the imgur link
https://imgur.com/a/blSL3Qr
« Last Edit: February 24, 2019, 06:58:52 am by simondid »
Offline Nusa
Re: what connector is this ?
« Reply #1 on: February 23, 2019, 03:19:20 pm »
Whats the brand name on the microphone? That would probably be essential to searching for ready-made products.
What's the far end of the cable look like? Perhaps it's easier to add an extension at that end?
Offline simondid
« Reply #2 on: February 23, 2019, 05:09:01 pm »
the microphone is unnamed
the microphone is a product called "cardo pack talk slim"
https://imgur.com/a/Jb4J74U
I don't want to open/modify the cable that is connected to the unit as it's very small
Online dunkemhigh
« Reply #3 on: February 23, 2019, 05:33:25 pm »
No idea what it is, sorry, but can I ask that you upload the images with your message in future? There are two reasons for this:
1. A reader can see what you're asking about without having to trundle off elsewhere on the web (particular when that elsewhere might have another set of scripts to deal with).
2. Off-site images can go AWOL at the whim of the image host, so then these posts will be meaningless. Keep the images here and this thread might help someone in future.
Offline Richard Crowley
  • KE7GKP
« Reply #4 on: February 23, 2019, 05:54:15 pm »
That appears to be a proprietary/custom connector made for CardoSystems. Probably your only option is to contact CardoSystems to see if they have anything.  Don't hold your breath.
But CardoSystems may discover that an extension cable is something that they should sell.
Else perhaps you can get an old broken set and make your own extension cable from recycled connectors from a dead set.
Or some desperate people search out compatible male and female pins (like pins from DB25 connectors?) and form their own male and female connectors by molding them from DIY plastic (like Sugru)
Or just bite the bullet and chop the cable and splice in a longer length.
Or, do you need to retain the ability to connect and disconnect?  If not, dump the proprietary connectors and splice in a longer cable.
« Last Edit: February 23, 2019, 06:02:52 pm by Richard Crowley »
Offline simondid
« Reply #5 on: February 24, 2019, 06:50:05 am »
thanks for the responses
dunkemhigh:
the image function did not work so i just posted the link but after looking into it it seems like I used the wrong link ... :(
but use that link in the feature
richard Crowley:
I do need to retain the option to connect/disconnect and splicing is not really an option as the cable is like 1 or 2 mm thick with 2 wires inside. I have trayed splicing small stuff before and it never turned out great due to the small size :(
The following users thanked this post: dunkemhigh
Offline Nusa
« Reply #6 on: February 24, 2019, 07:05:38 am »
If you can't obtain the original connectors, your other option is to pick a new connector pair to replace the existing connectors. Then making an extension cable becomes easy.
Offline simondid
« Reply #7 on: February 24, 2019, 07:12:25 am »
nursa :
that's a good idea for a last resort :)
Offline timelessbeing
« Reply #8 on: February 24, 2019, 08:00:31 am »
There is a stickied topic right at the top for this kind of question.
https://www.eevblog.com/forum/chat/what_s-this-please-(component-advice)/
