A friend has a potential transformer that's very modestly rated... the trick is, because they're intended to sense the potential very accurately, the coupling factor is very high. They're not intended for many VAs, but a high VA capacity is necessary and sufficient for their desired operation. Indeed, they have much lower leakage than a conventional type does, which makes them... very exciting indeed, for high voltage testing!
In practical terms, it really just means you need a ballast on the primary side, and then you can use them for whatever you like.
Needless to say, the friend has documented just how large of an arc you can get from a residential (US) feed, before the breaker opens the circuit.
