The approach is probably interesting, but I could not find any (after admittedly a quick search) other publication on that. Which in itself is not a good sign.
As to implementation, I would be a lot more reserved.
First thing (that I may have missed, or the author may have not stated): is this properly isolated? Is this battery-operated, or otherwise has proper isolation means?
Second thing, it's apparently just a fixed, constant voltage, alterning stimulation. I think this is the wrong way of doing it. It should be current-controlled instead. The resulting impedance between electrodes will vary widely depending on conditions, skin, skin preparation, and other factors. Thus the stimulation current will vary widely. This is definitely neither a good idea for safety, nor for reproducibility.
For those reasons, and the fact it's solely an experiment the author did on themselves, I'm surprised this got even published. Since when experimenting on oneself (with all biases that can come with it) can be a valid scientific approach?
