When I was doing it, MIG with aluminum filler needed a spool-on-gun. I visited a shop that did truck body modifications. They used aluminum diamond plate and MIG exclusively. I thought the welds looked pretty good start to finish.
Besides working with very thin materials, if you flush the back side of the weld with shielding gas (I use argon exclusively), you can get a through weld where the back looks as good as the front. It takes time and for me good hearing. The sizzle changes tone. You can also see a change in the puddle with steel. I have not tried that with aluminum sheet.
I use a variable foot control rather than something on the torch. TIG also makes great welds on thermocouple probes. For structural, like 8mm steel, you really need the amperage. That's where I use MIG, unless it's just for fixturing.
