Some of the smartest electronics people I knew were experienced TV technicians.
Smart in a limited practical area sufficient for their job.
They didn't need broad theory to do their job.
What are the TV technicians doing now? Retired? Dead? Or gone onto other pursuits in electronics, or even completely other industries? Maybe some are in this forum. It will be interesting to know what you are now doing today, and maybe your thoughts on the demise of electronics repair and its impacts.
Repairing computers.
The thing is, they did have a solid background of theory, although not to an EE level.
When he was a kid, Dick Feynmann worked in a radio/TV repair shop. He became known as the person that repaired them by analysing the problem from theory, then applying the fix. The other technicians simply changed valves until the radio started working again.
Ohh, you mean the guy that took 5 times as long!
Most problems with things like domestic valve radios can be relatively easily diagnosed by application of a lot of experience & a tad of theory.
All fault finding regimes stress "looking for the obvious" first, but that doesn't mean Techs don't have to use theory.
I have never worked in a TV repair shop, but for many years, I was basically, a TV transmitter "fixer upper", who as my "other identity", had to fix TV picture monitors, the odd TV set, & some other weird stuff that came across the bench.
It is hard to put EEs on a pedestal, when you see some of the design stuff ups made by those from quite prestigious companies.
This was often compounded by the propensity of some such companies to supply very poor service information.
