Lets see if I can remember correctly .
Using acid is & was not used in any soldering of plumbing , its mostly semantics - as our knowledge base grows , we need / use more terms to get more specific .
There use to be , mostly in the automotive industry for radiators " acid-core-flux " .
Not use in plumbing , for some of the same reasons for not using lead solder .
Again as I remember part of the purpose of using acid-core-flux was soldering of older , used copper parts radiators , or pipe for other than potable water .
The acid-core-flux was to shorten labor times , as to not have to clean oxidized copper , the acid removed the oxidation .
I have not seem it around for a few decades .
