Author Topic: what noises are these?  (Read 1602 times)
Offline loop123Topic starter
« on: February 03, 2024, 09:58:34 am »
Input signal is 40Hz. It started with high pass filter switched to 100Hz. Then when I switched it to 1000Hz, the noises started showing up, and becoming worse at 3000Hz, 10000Hz, 30000Hz, 50000Hz. Halfway I switched it back from 50000Hz back to 100Hz where the noise vanishes.
Without the 40Hz. Does it mean there are high frequency waveforms at 0V origin? What usually caused such high frequency ripples in any circuit?
Offline ebastler
Re: what noises are these?
« Reply #1 on: February 03, 2024, 07:54:22 pm »
I just saw that you double-posted this (in the Beginners section). Please don't do that, it makes you rather unpopular. It confuses readers, and it makes people waste their time trying to answer the second copy of your question, duplicating the effort that may already be underway elsewhere.
Offline Halcyon
  • Global Moderator
« Reply #2 on: February 03, 2024, 10:25:29 pm »
Duplicate post.
The following users thanked this post: ebastler
