Sorry for the bad pun in the headline, I simply couldn't resist...
tl;dr What no clean lead-free tacky flux do you use / can recommend for hot air rework of the usual suspects (QFP, QFN, SOIC, small BGAs etc. pp.)?
While I'm awaiting delivery of a AOYUE (the unpronouncable brand) hot air rework station, I already started looking for a tacky flux. Despite Louis Rossmann being one of my YouTube subscriptions, I do not wanna run straight towards his praised AMTECH flux. Currently I'm using EDSYN FL 22 R for normal soldering of THT, but from its dark color it appears to have quite a lot rosin in it. Might not be what you want to get sucked under your ICs by capillary effect, where it will be pretty impossible to clean it (I do not own an ultrasonic cleaner), even if it's supposed to be "no-clean". It is 1.1.2 according to ISO 9454-1 (= Rosin with halides), so you want to clean that off..
After watching this video from Steve Gardner
https://youtu.be/iKDAmY9Rdag, I wasn't that much wiser than before (although I didn't know that liquid flux evaporates thaaaat fast, this is why I wanna go for tacky/paste flux). Some of the Banggood stuff he tested had severe flux spitting when it liquified, you don't really want that. Another big problem with many of those cheap fluxes is, that you know near to nothing about the level of corrosive residues they leave behind. Problem with the AMTECH stuff: most of it is not genuine, but a cheap knockoff. I would not say that makes it a bad choise - it simply makes it a more unpredictable choise in terms of what to expect.
Syringes of 5-10 CCM should be fine for my "hobby needs".
I spent almost a whole day looking through different offers now (wasted would be a more appropriate expression), so I'm now turning to you and would kindly ask about some recommendations.
Kind regards from Germany - and stay save!
