Author Topic: What Would be Reason for Cordless Screwdriver to Fail?  (Read 1898 times)
Offline Boris_yoTopic starter
  • Country: il
« on: November 20, 2021, 10:45:54 am »
Hello,
I had B&D screwdriver for over a decade and today when I wanted to use it, it failed.
There was strange liquid on it but so was on other tool inside my tool chest so I am not sure if liquid belongs to screwdriver.
It has been stored without batteries and I have not used it much.
How can such tool fail without being used? Used it a few times for short duration.
There is a small steel bar with notch on back of the head so maybe I can open it?
Offline tunk
  • Country: no
Re: What Would be Reason for Cordless Screwdriver to Fail?
« Reply #1 on: November 20, 2021, 12:30:37 pm »
Corroded switches/contacts, gummed up bearings?
Offline nctnico
« Reply #2 on: November 20, 2021, 12:43:17 pm »
No. It says it on the outside: 'Black&Decker'
  • Country: il
« Reply #3 on: November 20, 2021, 02:08:04 pm »
What's wrong with B&D?
Offline Nusa
« Reply #4 on: November 20, 2021, 05:14:05 pm »
I assume you've verified all the batteries are good?
I've taken that model apart before and fixed it for my neighbor, twice now. Removing that U clip will allow the gearhead to be pulled off. Tilt the black part down to avoid dropping gears on the table. Once the gearhead and battery clip are removed, you can split the red case carefully. It's electrically simple -- there's nothing in there but the motor, battery and switch contacts, which can be further disassembled. The problem is almost always bent or oxidized contacts.
« Last Edit: November 20, 2021, 05:15:54 pm by Nusa »
The following users thanked this post: Boris_yo
Offline Rick Law
« Reply #5 on: November 20, 2021, 09:47:35 pm »
I think you need to download the latest software update for it to work right.  With the latest update, not only can the manufacturer email you with failure diagnostics, you can run your screw driver entirely with the app just by touching the screen...
(Sorry...  can't resist.   But I think we can all use some humor in our life.)
Offline G7PSK
  • It is hot until proved not.
« Reply #6 on: November 21, 2021, 03:11:25 pm »
B&D say no more.
Offline PlainName
  • Country: va
« Reply #7 on: November 21, 2021, 10:42:36 pm »
Not all B&D are, er, B&D-alike. Got a battery drill which is still excellent despite the nicads (second set) being pretty much dead. Also a jolly expensive vacuum which is very decent.
I think it must be like HP where they used to be good but are now shit, except for a very few diamonds that've been overlooked.
Offline Nusa
« Reply #8 on: November 21, 2021, 11:13:49 pm »
  • Country: il
« Reply #9 on: November 22, 2021, 01:10:27 pm »
Contacts are acting strange. Reverse button when pushed with no pressure does not start motor but when I release it, it starts motor for a brief moment only.
When I push reverse button hard, it works okay. With forward button same thing except when I push left edge it works good but when I push center or right edge, it does not work. I have 70% alcohol and 99% isopropyl alcohol. Maybe I should rub contacts?
  • Country: il
« Reply #10 on: November 22, 2021, 01:16:05 pm »
B&D say no more.
I saw $16 sale on Banggood for Topshak rechargeable 4v screwdriver. Locally there is a sale of B&D 3.6v for $42. I guess for you both are same?
