Ok I need help with this one. I got a Fluke 83 series I
Ok I need help with this one. I got a Fluke 83 series I in auction that won't turn on. I had almost given up having checked all the usual stuff like fuses etc which are all fine. Until tonight I was bored checking random part values and noticed there was only 68ohms resistance between the positive and negative battery terminals. Hmm I wonder why it wouldn't start. After removing several items that tested bad in circuit, but were fine out of circuit, I came across this. It's clearly bad (roughly 50 ohms across every terminal), I am guessing that it is a bjt of some sort but my googlefoo is failing me. I apologize if it's easy but my laptop is off for warranty repairs so I'm limited to phone searches. The item doesn't have a designator number on the silk screen but it was located top right beneath the LCD.Thanks guys and gals for your help. Hopefully I can save another device from the trash can.Sent from my EVO using Tapatalk
SMD Diode identification, EPP 47 is all that's marked, Becker Indianapolis BE7920Picture attached, was taken with mobile phone, do not have a digital camera handy.https://www.dropbox.com/sc/krzm94a01vecd4o/qermgHRZSY
Quote from: TheBay on December 16, 2013, 09:37:52 pmSMD Diode identification, EPP 47 is all that's marked, Becker Indianapolis BE7920Picture attached, was taken with mobile phone, do not have a digital camera handy.Picture here:www.useasmallerpicture.com
Quote from: TheBay on December 19, 2013, 02:34:20 pmQuote from: TheBay on December 16, 2013, 09:37:52 pmSMD Diode identification, EPP 47 is all that's marked, Becker Indianapolis BE7920Picture attached, was taken with mobile phone, do not have a digital camera handy.Picture here:www.useasmallerpicture.comDoes this seem appropriate:http://www.vishay.com/docs/88407/tpsmc68tpsmc47a.pdf
Thank you for this, makes some sense I wonder if excess voltage supplied i.e. 24v caused it to go S/CThis is the logo on the device, who is the manufacturer?Quote from: peter.mitchell on December 20, 2013, 09:21:25 amQuote from: TheBay on December 19, 2013, 02:34:20 pmQuote from: TheBay on December 16, 2013, 09:37:52 pmSMD Diode identification, EPP 47 is all that's marked, Becker Indianapolis BE7920Picture attached, was taken with mobile phone, do not have a digital camera handy.Picture here:www.useasmallerpicture.comDoes this seem appropriate:http://www.vishay.com/docs/88407/tpsmc68tpsmc47a.pdf
Quote from: TheBay on December 20, 2013, 09:45:43 amThank you for this, makes some sense I wonder if excess voltage supplied i.e. 24v caused it to go S/CThis is the logo on the device, who is the manufacturer?Quote from: peter.mitchell on December 20, 2013, 09:21:25 amQuote from: TheBay on December 19, 2013, 02:34:20 pmQuote from: TheBay on December 16, 2013, 09:37:52 pmSMD Diode identification, EPP 47 is all that's marked, Becker Indianapolis BE7920Picture attached, was taken with mobile phone, do not have a digital camera handy.Picture here:www.useasmallerpicture.comDoes this seem appropriate:http://www.vishay.com/docs/88407/tpsmc68tpsmc47a.pdfThat logo is for General Semiconductor, who are now owned by Vishay Technology, the above mentioned company.The device is a TVS, it is designed to go short circuit to clamp voltages to a specified level, this one, marked EPP states 23.1v maximum working voltage, and 25.7v-28.4v breakdown voltage. Whilst designed to withstand high currents for short periods of time (to clamp the voltage), expectedly, it will be damaged under exceptional stress for extended periods.The wikipedia page is quite helpful in regards to this device. http://en.wikipedia.org/wiki/Transient-voltage-suppression_diode
Have seen that logo a few times but had no idea what manufacturer it is,
Quote from: TheBay on December 20, 2013, 04:19:40 pmHave seen that logo a few times but had no idea what manufacturer it is,Just like there's SMD marking databases online, there's also semiconductor logo databases available.E.g. these ones:http://www.dibsplace.com/design/ICLogos.htmhttp://www.elnec.com/support/ic-logos/http://how-to.wikia.com/wiki/How_to_identify_integrated_circuit_%28chip%29_manufacturers_by_their_logoshttp://www.chipdocs.com/logos/logotypes.htmlhttp://www.classiccmp.org/rtellason/logos/semiconductorlogos.htmlhttp://www.dialelec.com/semiconductorlogos.htmlhttp://www.westfloridacomponents.com/manufacturer-logos.htmlhttp://freespace.virgin.net/matt.waite/resource/logos/Only the last of the above links doesn't have the GS logo and the associated General Semiconductor name, but only show an older star logo for GS.
BTC 0207-010F All I know is that it is the chip inside the Brymen-257/Greenlee-510A. Thanks.
Quote from: cubemike99 on January 29, 2014, 03:05:49 amBTC 0207-010F All I know is that it is the chip inside the Brymen-257/Greenlee-510A. Thanks.BTC is most likely short for BRYMEN TECHNOLOGY CORPORATION, which is the full company name: http://www.brymen.comSo it's probably some kind of custom chip, and datasheets or other documentation is usually not available for custom chips.
How do I identify these diodes (schottky, zener etc.), and what do the stripes mean?
With my DMM, I measure nothing ("1") in either direction.
