NTC's are used in SMPS input stages as well, to reduce inrush current. I have used them on incandescent lamps as a life extender, as the lamp will generally last thousands of hours, as the most stress occurs during switch on, and the added resistance reduces this until the filament is so weak that it blows during use. I had to do this on an old plate maker that used 40 40W golfball lamps as a light source, that had a switch on surge that would trip the 30A mains breaker 50m away down the corridor. I could not find a NTC that would handle the load ( and this was in the 1970's when I was a teenager) so used a slow start circuit which had a triac controlled by a unijunction transistor (now near impossible to get) and a few other components to provide a slow charge ( 1 second from zero to full brightness) and a non isolated supply for the circuit.
I did a similar thing for my variac, it has a very large core and a correspondingly annoying switch on surge.
