Author Topic: What's this please? (Component Advice)  (Read 1339292 times)
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
Re: What's this please? (Component Advice)
« Reply #1500 on: April 19, 2019, 03:09:10 pm »
Additionally, if you go to the manufacturer's website, they often have a link somewhere on the part's page that will list known distributor stock.  This will show you which distributors have that particular part, and how many they have. It's not 100% accurate as it's not necessarily updated in real time, but should be within a day or so.  I've found it to be a big timesaver when looking for oddball stuff in that it can save you the trouble of having to look everywhere as it at least gives you a feel for who doesn't have it...
-Pat
Offline dnotq
« Reply #1501 on: April 19, 2019, 05:37:09 pm »
@Nusa: Thanks for the research!  I also found the 60-pin part, via Octopart, in stock at Arrow.
@Cubdriver: Yeah, checking the manufacturer's page for "how to buy" is something I do a lot too.  Sadly, the 3M website is pretty crappy in that aspect and I could not find any information about distributors on their product page.
Offline Pluscrafter
  • Somewere on earth
« Reply #1502 on: April 28, 2019, 05:45:54 pm »
Could anyone find out what this is? A tranistor? It was in the dumpster from my school and i can't find any information in the internet. It could be from the 70'ties or 80ties.
Online PA0PBZ
« Reply #1503 on: April 28, 2019, 05:58:20 pm »
Can you show the other side?
Offline Pluscrafter
  • Somewere on earth
« Reply #1504 on: April 28, 2019, 06:02:47 pm »
Its a three pin device and it maybe a transistor(pnp) because you can measure the typical voltagedrop over the pins.
« Last Edit: April 28, 2019, 06:05:24 pm by Pluscrafter »
Online PA0PBZ
« Reply #1505 on: April 28, 2019, 06:12:21 pm »
It sure looks like a transistor. I wonder if the first M is the Motorola logo, and I'm also not sure what the second letter is. I think the last line is the date code, week 36 1981.
Offline Pluscrafter
  • Somewere on earth
« Reply #1506 on: April 28, 2019, 06:18:37 pm »
I think "MHH" are the letters.
Offline amyk
« Reply #1507 on: April 28, 2019, 06:42:54 pm »
That appears to be a 2N1614.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #1508 on: April 28, 2019, 06:46:26 pm »
Motorola MM1614
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: Pluscrafter
Online PA0PBZ
« Reply #1509 on: April 28, 2019, 06:49:40 pm »
Motorola MM1614
So 'MM', didn't see that...
Offline Pluscrafter
  • Somewere on earth
« Reply #1510 on: April 28, 2019, 07:18:15 pm »
Thanks. I though that were "H"'s.
Offline 6PTsocket
« Reply #1511 on: April 28, 2019, 08:41:23 pm »
It is a Motorola 2N1614 transistor in a TO5 type case. Since the Jedec system prefexed all transistors with 2N it was common to leave it off , just like the European and Asian transistors were marked 2SA, 2SB, 2SC and 2SD the 2S was usually omitted. That is what many small signal transistors looked like in the early days. Just google 2N1614 and it pops right up. Case shapes are assigned an industry number. The large TO 5 is not seen much any more for small signal transistors.
Sent from my SM-G900V using Tapatalk
Offline @rt
« Reply #1512 on: May 15, 2019, 07:08:31 am »
Hi :)
This is very close (in shape of the metal shroud) to a USB mini plug.
It has 11 internal pins, not including the metal shroud, so 12 conductors.
It’s a Yaesu handheld transceiver programming cable, so if the part is some stock component, it would be far cheaper to make one than buy it.
Anyone find it familiar?
Offline tsmith35
« Reply #1513 on: May 15, 2019, 11:31:29 pm »
You might check this out... http://www.eenewseurope.com/news/11-pin-io-connector-comes-format-similar-mini-usb
Offline @rt
« Reply #1514 on: May 16, 2019, 12:04:33 pm »
I’m quite sure that’s it, but still can’t find it to buy! :D
Offline Ysjoelfir
« Reply #1515 on: May 17, 2019, 06:22:01 am »
Well, the article gives you many informations:
Under the model designation 020036MB011M50XYZR, Suyin announced two greatly miniaturized surface-mount I/O connector receptacles with a design that is similar to the Mini-USB format.
These receptacles are supplied in tape & reel packaging; the mating plugs are supplied on trays and are available in minimum order quantities of 80,000 pieces per year or more.
Visit Suyin at www.suyin-europe.com
Just visit them and ask where you can buy those things.
Greetings, Kai \ Ysjoelfir
Offline @rt
« Reply #1516 on: May 18, 2019, 03:00:52 am »
I did find a supplier with minimum order of 37.
Looks like I’ll be selling some cables :D Thanks.
Offline windsmurf
« Reply #1517 on: May 24, 2019, 06:12:51 am »
Can someone tell me what this is next to the piezo speaker? How does one go about testing this part?
Thanks in advance!
Offline timelessbeing
The following users thanked this post: windsmurf
Offline Ysjoelfir
« Reply #1519 on: May 24, 2019, 06:24:48 pm »
Hey everyone,
just got my hands on a few of those 1Ohm .1% shunts. since it has been discontinued quite a long time ago (our purchasing department said around '93) I can't find any datasheet. Since I know where this was used I assume it is a quite nice shunt, but I would love to know more about, especially in regards of stability over time and temperature. eventually someone knows anything?
On the thing it says:
BADER C51b
BMN 1/1 1R00 0.1
Edit: Just found another part in the pile which is supposedly an equivalent. It is an Isabellenhütte S45 A-N-1R00-F1-K2-0.1. Looks identical to the BADER one, just different marking. If nobody knows anything I may phone the guys at Isabellenhütte, AFAIK they are quite friendly :)
« Last Edit: May 24, 2019, 06:29:00 pm by Ysjoelfir »
Offline Ubernuton
« Reply #1520 on: May 28, 2019, 09:06:55 am »
Any idea what this is? I'm fairly sure it came out of an old stereo.
Online PA0PBZ
« Reply #1521 on: May 28, 2019, 09:48:22 am »
Looks like an IF filter, first I thought for the FM IF (10.7Mhz) but the 459 suggests it's for the AM IF.
[Edit] See here: https://www.changpuak.ch/electronics/ceramic_filters/muRata_Filters.pdf
« Last Edit: May 28, 2019, 09:50:20 am by PA0PBZ »
Offline Ubernuton
« Reply #1522 on: May 28, 2019, 10:55:59 am »
That looks about right. Thanks
Offline @rt
« Reply #1523 on: May 30, 2019, 05:03:39 am »
The part next to the piezo speaker is probably a diode to prevent reverse current damaging whatever is driving it.
Offline Cyberdragon
« Reply #1524 on: June 02, 2019, 10:58:56 pm »
Thanks in advance!
Looks like a glass cased MLC capacitor.
*BZZZZZZAAAAAP*
Voltamort strikes again!
