Author Topic: What's this please? (Component Advice)  (Read 557805 times)
Offline orbiter
  • -0 Resistance is Futile
« on: March 06, 2011, 12:21:48 pm »
Hi fellas,
First off... Anybody think it might be a good thing to have a 'What's This Please..' as a sticky thread, and if so, could we have one please? Only because I've seen a few people (including myself) needing to know what particular parts are.
Ok now to my question.. What's This please.. :) I'm assuming it's some sort of photodiode or something, but I've had a quick search on around on the datasheet sites looking for the displayed numbers, but I can't see anything that matches.
Thanks guys
« Last Edit: March 09, 2011, 08:04:21 pm by orbiter »
The following users thanked this post: radiorich
Offline cybergibbons
Re: What's this please?
« Reply #1 on: March 06, 2011, 12:32:30 pm »
Looks like an IR remote receiver.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: March 06, 2011, 12:32:51 pm »
It's an infra-red receiver for remote controls, by Sharp I think. It demodulates the 36-ish khz carrier to give an easily decoded datastream. There are many simiular devices (e.g. Vishay TSOP range), sho shouldn;t be hard to find data
Day Job: Mostly LEDs
Offline orbiter
« Reply #3 on: March 06, 2011, 12:39:45 pm »
Ah ok, thanks guys. That gives me something to go on.
Cheers
orb
Offline Sionyn
« Reply #4 on: March 06, 2011, 03:58:53 pm »
IR
eecs guy
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: March 06, 2011, 03:59:14 pm »
First off... Anybody think it might be a good thing to have a 'What's This..' thread, and if so, could we have one please?
i agree, and it should be made sticky. how about this thread? just suggestion.
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Offline armandas
  • Country: jp
    • My projects
« Reply #6 on: March 06, 2011, 11:16:38 pm »
Oh! Oh! May I?
The hand drawn part is the rough copy of the silk screen that was under the component. Basically a zigzag in a rectangle. Probably some power component, but I have never seen the symbol, so no idea.
EDIT: added a picture with a ruler. It's about 10mm wide.
« Last Edit: March 06, 2011, 11:23:56 pm by armandas »
Offline dengorius
« Reply #7 on: March 07, 2011, 02:09:00 am »
It looks like some kind of thermistor to me, maybe a NTC? Have you tried to measure its resistance
Offline Hypernova
  • Country: tw
« Reply #8 on: March 07, 2011, 06:20:11 am »
At that size probably a NTC thermister for inrush current protection.
« Last Edit: March 07, 2011, 06:30:18 am by Hypernova »
Offline ElektroQuark
    • ElektroQuark
« Reply #9 on: March 07, 2011, 07:52:19 am »
Semitec 10D210 Thermistor, NTC, 10 Ohm, 3A
Offline armandas
  • Country: jp
    • My projects
« Reply #10 on: March 07, 2011, 08:50:33 am »
Nice one, guys. It is indeed an NTC, measures about 12R when cold. Thanks!
Offline orbiter
« Reply #11 on: March 09, 2011, 05:00:34 pm »
Any chance of the 'What's this please?' sticky thread.. please mods?
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #12 on: March 09, 2011, 07:32:29 pm »
There you go it is now a sticky. It will eventually become a very long topic though but I expect something to trwl through when you have an "unknown" and "some time"
Offline orbiter
« Reply #13 on: March 09, 2011, 07:55:36 pm »
Great. Thanks Simon :)
Online NiHaoMike
    • Facebook Page
Re: What's this please? (Component Advice)
« Reply #14 on: March 10, 2011, 08:31:28 pm »
In every CRT monitor or TV I have taken apart, there was this odd inductor that has a permanent magnet glued to it. Is that to offset the magnetic field generated by a DC bias current so a cheaper core can be used?
Offline Time
« Reply #15 on: March 10, 2011, 10:38:32 pm »
My guess would be to minimize the overall field of the inductor since a CRT is sensitive to B fields.
-Time
Offline david77
« Reply #16 on: March 10, 2011, 10:59:22 pm »
I've also got something I'm seeking information on. I'm pretty sure I know what they are but I'd be interested in some more info on these op amps.
Offline jahonen
« Reply #17 on: March 11, 2011, 08:05:01 am »
I think it is horizontal linearity or "s-correction" coil.
Regards,
Janne
Offline apex
    • Thoughts of a nerd
« Reply #18 on: March 12, 2011, 01:21:59 pm »
@david77:
They look like early operational amplifiers.
The function on the pins is printed on it, so why don't give it a try and see if it works?
Don't expect too much amplification factor!
apex
Offline Zero999
  • 0999
« Reply #19 on: March 12, 2011, 05:27:23 pm »
Yes, that's what it's for, the permanent magnet biases the inductor to oppose the DC current so a smaller, cheaper core can be used.
  • Country: my
« Reply #20 on: March 15, 2011, 04:44:08 pm »
pls help!
1) white (ceramic like) rectangle with 5W0.1ohmJ on it?
2) yellow (plastic like) rectangle with .1uF (K) X2 etc etc on it? if its capacitor, what type and why its yellow plastic rectangle?
3) the green round coin shape with DN R, 20 D471K on it, polyswitch right? the NTC?
« Last Edit: March 15, 2011, 04:46:54 pm by Mechatrommer »
Online NiHaoMike
    • Facebook Page
« Reply #21 on: March 15, 2011, 05:02:51 pm »
First one is a resistor.
Second one is indeed a capacitor.
Third one is a NTC.
  • Country: my
« Reply #22 on: March 15, 2011, 05:09:49 pm »
thanx. but why the unit is ohmJ? and my question about the yellow rectangle plastic?
Offline Simon
  • Global Moderator
« Reply #23 on: March 15, 2011, 05:24:05 pm »
I think "J" is an abreviation of tolerance, 5% I think
Offline Fryguy
« Reply #24 on: March 15, 2011, 05:51:08 pm »
1) it's a simple 0,1 ohm 5W resistor - just ignore the J - i always do  ;)
2) is a X2-class 0,1µF mains filter capacitor - a flat foil capacitor in a yellow plastic block body - that's just the way it is - an X2 is designed to withstand a voltage peak of 2500V and it won't burn in case of an overload .
May the forces of evil get confused on their way to your home !
