Author Topic: What's this please? (Component Advice)  (Read 556106 times)
Offline IO390
Offline tautech
Re: What's this please? (Component Advice)
« Reply #776 on: May 15, 2015, 10:41:25 am »
http://www.nxp.com/documents/data_sheet/2PB1424.pdf
I love you
Now, now, that will do.
"M1 marking SMD SOT-89 IC data", first hit in Google, then follow your nose.....  ;)
Avid Rabid Hobbyist
Offline amyk
« Reply #777 on: May 15, 2015, 04:14:54 pm »
A 2PB1424 is marked M1, but not the only device to have that marking. Especially if you think it's an LDO...
Offline Terabyte2007
  • It is purpose that created us... That defines us..
« Reply #778 on: May 16, 2015, 11:03:22 pm »
Anyone know what this part is? I can't seem to find a datasheet on it. Any help would be greatly appreciated!
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline tautech
Avid Rabid Hobbyist
« Reply #780 on: May 17, 2015, 12:07:57 am »
Offline tautech
« Reply #781 on: May 17, 2015, 12:15:20 am »
Try this one: http://www.seekdatasheet.com/Datasheet-72946-60K860B.html
That link took me to an ZXRD1000 Inductor part. ???
Bugger, sorry, net is slow here today and it looked promising.
Well at least your post got a bump.
Avid Rabid Hobbyist
Online wraper
  • Country: lv
« Reply #782 on: May 17, 2015, 12:19:57 am »
60KQ60B schottky diode.
« Last Edit: May 17, 2015, 12:24:45 am by wraper »
« Reply #783 on: May 17, 2015, 12:53:00 pm »
Thank's man. I thought the Q was an 8.
Offline kolonelkadat
  • Obviously, windows are central to Windows.
    • Force Project X
« Reply #784 on: May 21, 2015, 12:02:16 am »
I cant seem to get any love from google recently.
Offline tautech
« Reply #785 on: May 21, 2015, 03:16:01 am »
Did you include the package type in your search?
"R32 marking SMD TO-?? datasheet pdf" or some thing like that mostly seems to work for me.
Avid Rabid Hobbyist
    • Force Project X
« Reply #786 on: May 21, 2015, 07:06:02 pm »
i did. Ive tried pretty much every combination of text on the package i can think of too.
Offline amyk
« Reply #787 on: May 22, 2015, 02:07:39 am »
Check ON's site. If you're desperate you can go through all their sot-223 datasheets, or email them with that picture.
R32 is a datecode, it's 3064 that you'll need to figure out.
Offline nostromo
« Reply #788 on: May 22, 2015, 05:50:51 pm »
Couldn’t find this one used in IBM SystemX SSD 50GB (P/N: 43W7714)
SMD marking code is AEL with some bars above and below. Package dimensions looks like a SSOT25.
The closest I could find is Torex XC74xxx series but couldn’t find SMD mark info in the document.
Online PA0PBZ
« Reply #789 on: May 22, 2015, 06:47:01 pm »
Offline nostromo
« Reply #790 on: May 22, 2015, 08:29:03 pm »
Thanks for the reply.
The problem is that AEL seems to be a SSOT25 and the datasheet doesn't mention this package.
In the picture below you can see A04G (the voltage detector SOT25) and the AEL at its side.
Offline LukeW
« Reply #791 on: May 30, 2015, 04:52:16 pm »
An "identify that component" challenge:
28-pin 0.3" DIP IC, possibly some sort of microcontroller.
Markings have been deliberately etched off.
It's from a cheap eBay-generic serial CNC handwheel pulse generator - maybe something old, or something obscure from China.
Pin 4: UART RXD
Pin 5: UART TXD
Pin 6: 11.0592 MHz crystal, plus typical crystal load capacitors.
Pin 7: Other side of the crystal oscillator.
Pin 14: Ground
Pin 28: +5V supply.
Any takers?
Offline Randall W. Lott
« Reply #792 on: June 02, 2015, 09:12:57 pm »
Any idea what this is?
- Randy
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #793 on: June 02, 2015, 09:32:12 pm »
High voltage resistor divider, probably.  ...and frequency compensated with the blue ceramic cap.
« Last Edit: June 02, 2015, 09:38:07 pm by Yansi »
Offline nali
« Reply #794 on: July 28, 2015, 08:07:36 pm »
Wonder if anyone can offer pointers to this please? Not sure what the package is but C18 is an 0805 for reference. I can't quite work out if the lines are indicating fields e.g. date code.
From tracing assuming pin 1 is at the bottom of the pic I can say pins 1&2 are 0v, pin3 is +5v and the others are analogue signals which I'm trying to trace. Maybe some sort of clamp?
Thanks
N
Offline tautech
« Reply #795 on: July 28, 2015, 10:13:02 pm »
Looks like a SOT23-6 package.  :-//
Theres a few CF* devices you could check for a match here:
http://www.s-manuals.com/smd/cf
Avid Rabid Hobbyist
Offline Yansi
« Reply #796 on: July 28, 2015, 11:42:16 pm »
INA213 - about a minute or two of googling. Grhhhhh.
http://www.ti.com/lit/ds/symlink/ina210.pdf
Offline nali
« Reply #797 on: July 29, 2015, 07:00:23 am »
Thanks, that's the one! Out of interest, what did you Google? I tried searching and a few sites like s-manuals.com & smdcodes.com but didn't get any hits for a 6-pin device. In the end I opted for a punt on here and some sleep...
Offline AndersAnd
« Reply #798 on: August 05, 2015, 08:15:01 pm »
I wasn't the one googling it, but just tried to google "SOT23-6 CFT" and this showed up as the 4th hit:
http://www.aliexpress.com/item/INA213AIDCKT-TI-Chip-screen-printing-CFT-SOT23-6-IC-100-new-original-Free-shipping/1888451678.html
INA213AIDCKT TI Chip screen printing:CFT SOT23-6 IC 100% new original Free shipping
    • Force Project X
« Reply #799 on: August 12, 2015, 08:21:32 pm »
I found this on the ground at the park today. I suspect its part of some sort of drone, but i dont know.
The micro is a PIC12F629. The back side is just a button and a battery holder.
When powered at ~3v3 the led blinks when you press the button, but stops as soon as you release it.
Anyone have any ideas?
