Author Topic: What's that "glue" used to fix bodge wires?  (Read 1766 times)
Offline mcinqueTopic starter
  • I know that I know nothing
« on: January 07, 2023, 12:50:51 am »
Hello all!
I always see that bodge wires on PCBs are often fixed with some kind of glue or adhesive.
It's not always the same type, some times is white silicon gunk, other times it's a precise drop of something clear (that's what I want to achieve).
See attachments.
There is a precise product to be used for that kind of thing?
« Last Edit: January 07, 2023, 12:54:19 am by mcinque »
Offline MarkS
Re: What's that "glue" used to fix bodge wires?
« Reply #1 on: January 07, 2023, 12:52:52 am »
The top pic appears to be clear hot glue.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: January 07, 2023, 12:55:45 am »
Hello all!
See attachments.
Might be UV glue. You set it with a UV light. I have some and it looks like that clear example.
« Reply #3 on: January 07, 2023, 12:59:19 am »
it is not clear glue, too transparent. And hot glue is very hard to apply in minimum quantities like in the first pic, for me that is not hot glue.
This is hot glue.
Offline Psi
« Reply #4 on: January 07, 2023, 01:24:20 am »
It might be clear electronic grade silicone.
Touching it to see how pliable it is should tell you if it's silicone vs a hard UV cure glue.
https://www.digikey.co.nz/en/products/detail/chip-quik-inc/EGS10C-20G/10059587
« Last Edit: January 07, 2023, 01:26:02 am by Psi »
Online bdunham7
« Reply #5 on: January 07, 2023, 01:25:45 am »
Likely a single-component epoxy in a small syringe.  You can get heat-cured or UV-cured versions.
Offline tooki
« Reply #6 on: January 07, 2023, 01:27:02 am »
What do you mean? "Clear" means "transparent".
Online Someone
    • send complaints here
« Reply #7 on: January 07, 2023, 02:54:08 am »
Plenty of glues advertise "clear" that is ok for a thin bonding application but end up a little milky in bulk cure. Which is why the industry had to add "optically clear" as a new category. Bonus points for refractive index matching.
Offline dobsonr741
« Reply #8 on: January 07, 2023, 03:14:28 am »
Search Amazon for “5 second Uv glue”. Works well on PCB bridge wires.
Offline rdl
« Reply #9 on: January 07, 2023, 02:13:36 pm »
UV curable coatings and glues do not contain volatile organic compounds (VOC), at least not in any significant quantity.
The following users thanked this post: bigfoot22
Offline tooki
« Reply #10 on: January 07, 2023, 02:16:12 pm »
I know that, but the line I was replying to was saying that it’s too transparent to be clear?
Offline tooki
« Reply #11 on: January 07, 2023, 02:17:24 pm »
NorthridgeFix calls it conformal coating and uses a UV lamp to set it. Dunno what the benefits are of using UV I suppose so that you don't melt your wires and the wires on the PCB don't move around while they are setting due to the wind from the heat gun.
One big benefit is that it cures very quickly, yet doesn’t have the problems of superglue (like having very little time to work with it). It’s also much easier to remove uncured glue.
The following users thanked this post: wraper, bigfoot22
Online wraper
  • Country: lv
« Reply #12 on: January 07, 2023, 02:35:42 pm »
The main benefit is that it's thermally stable and non conductive. It's the same as liquid type solder mask. Superglue is a bit electrically conductive and better not try to heat it, fumes are extremely nasty.
The following users thanked this post: tooki, bigfoot22
Offline Neomys Sapiens
« Reply #13 on: January 07, 2023, 07:28:05 pm »
The proper designation of this is 'wire tacking adhesive'.
