Author Topic: Whats this board?  (Read 1793 times)
Offline pepelevampTopic starter
Whats this board?
« on: October 31, 2019, 06:34:22 pm »
Just saw this on NZ's version of ebay called TradeMe. Anyone got some guesses as to what kind of board this is? Its in the vintage computing section, but it might not necessarily be computer / PC related.
I have one or two ideas but I'd like to see what you lot think
https://www.trademe.co.nz/computers/vintage/listing-2381126135.htm
« Last Edit: October 31, 2019, 06:37:16 pm by pepelevamp »
Offline jmelson
Re: Whats this board?
« Reply #1 on: October 31, 2019, 08:33:19 pm »
The C106 components are SCRs.
Jon
Offline Cyberdragon
« Reply #2 on: November 01, 2019, 12:24:06 am »
Jon
No, too new and the wrong package.
These are (2S)C106 signal transistors.
It appears to be from the late 60s to mid 70s and judging by the identical columns of components and use of lots of diodes (for logic) it appears to be a logic board out of something like a calulator or digital meter.
*BZZZZZZAAAAAP*
Voltamort strikes again!
The following users thanked this post: I wanted a rude username
Offline mengfei
  • Country: ph
« Reply #3 on: November 01, 2019, 03:16:23 am »
Offline VK3DRB
« Reply #4 on: November 01, 2019, 01:39:09 pm »
could be an IBM interace card  :)
Definitely NOT an IBM interface card for four reasons:
1. No IBM card soldered to gold tabs.
2. Prior to the early 1908's, IBM used their own part numbering schemes of everything, including discrete semiconductors.
3. Workmanship is generally poor. Wire-adds were never placed in such a haphazard way on IBM cards and there is no bevelling on the card connector edge.
4. ALL IBM PCBAs and PCBs have the part numbers and usually the EC number on them as well.
I worked for IBM for many years on a very wide range of equipment made from 1926 (ICT) until 1999, covering a broad range of technologies, from valves (vacuum tubes) right through to advanced VLSI. That includes IBM's SLT boards which are vaguely similar to the board shown here.
It looks like a board out of an old adding machine, early impact printer or OEM tape drive. In any case, EMC was never a consideration!
The following users thanked this post: mengfei
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #5 on: November 01, 2019, 02:10:48 pm »
Jon
I'm afraid he's right, and the names are THxxx => thyristors... !
https://pdf1.alldatasheet.com/datasheet-pdf/view/616889/NJSEMI/C106B1.html
Could be the driver for an 8 pins dot matrix head? Of a very early DMP... ?
« Last Edit: November 01, 2019, 02:17:20 pm by GeorgeOfTheJungle »
Offline SiliconWizard
« Reply #6 on: November 01, 2019, 03:13:45 pm »
Yes, the C106B1 is an SCR that was available from several vendors. B1 is the 200V version.
Mouser still holds a datasheet as well: https://www.mouser.com/ds/2/68/c106a1_series-534345.pdf
Could it be some kind of Nixie tube driver?
Offline Sal Ammoniac
« Reply #7 on: November 01, 2019, 03:31:27 pm »
Why are the traces soldered to the gold fingers on the edge connector? Why not just make them contiguous when laying out the board?
"That's not even wrong" -- Wolfgang Pauli
Offline Syntax Error
« Reply #8 on: November 01, 2019, 09:12:25 pm »
A longgggg time ago, I remember seeing circuits of this type, size and colour in our science class. Our teacher had a box of old circuits which he used to teach us the art of soldering and flux abuse. He was a former technician for the British General Post Office (now British Telelcom) and he'd obtain derelict exchange parts as teaching aids.
Looking at the distribution of components, it's certainly a three or four channel 'something'. It also looks like the solder has been used to make the tracks more robust. I would start my Googling for vintage telephone exchange equipment. The card's form factor certainly fits in an environment that needs a fast change-out. The PCD may be obvious when we know where this came from.
Maybe these are pulse or audio amplifiers? It would be cool if this was from something from a missile launcher or an early 1960's synthesizer, but without provenance, they're just 'vintage'.
« Reply #9 on: June 12, 2020, 01:27:22 pm »
Thanks fellas. Sorry for the late reply. I'm looking at 'PCD' in the top of the board there. Taking into account what you're saying about possible vintage exchange gear maybe this is a 'Pulse Code Decoder' ?
it just doesn't seem to have any blocks of logic that i can see anywhere. its all discrete stuff.
If those are all thyristors is this an amplifier or switch of some kind?  Power Control Device?
Something to get smooth power into the rest of the phone system?
Offline Ground_Loop
« Reply #10 on: June 12, 2020, 01:35:35 pm »
My old SD nixie counter has numerous SCR-based (actually 4-lead silicon controlled switches) counter cards for each display tube similar to what you've shown.  I'm guessing a counter/driver card.
There's no point getting old if you don't have stories.
« Reply #11 on: June 12, 2020, 02:45:45 pm »
Thats pretty cool. That sounds about right to me. Heh you know, even if thats not what it actually is - the fact that you could probably use the board to control a nixie is enough for me to consider the case closed. I like your signature about not getting old unless ya have stories.
Offline duak
« Reply #12 on: June 13, 2020, 12:38:38 am »
I count 8 SCRs so I propose a solenoid driver for a paper tape punch. 7 bit ASCII plus parity.  Remex and Facit ring a bell.
These things were also used on CNC machine tools to at least 1984.  In the days before PCs one could edit a CNC program on the built in computer and then punch out a revised version if need be.
« Reply #13 on: June 14, 2020, 04:45:33 am »
 :scared: zomg maybe you are right. that never even occurred to me.
