some new additions to my workbench with two 8U 19" racks:
All 3d printed parts are
hereracks:
![](https://i.imgur.com/QEvqRH0.jpeg)
![](https://i.imgur.com/p4gImS8.jpeg)
current 19" rack contents:
- Owon DGE2070 function generator
- Owon XDM1041 multimeter
- Ugreen 200W usb charger
- Riden/Joy-it RD6006 power supply
- AxxSolder 3.0
- 24v power supply with d-tap bus splitter outside
- 5v power supply with d-tap bus splitter inside and outside
- Network switch 8x 2.5Gb ports + 1x 10Gb SFP+
- Raspberry Pi Compute Module 4 with 0.91" oled display, NVME SSD and two USB hubs
- 12.6" ultra-wide touch screen(connected to the Compute Module 4)
- Rigol DHO924s oscilloscope
overview:
![](https://i.imgur.com/xDWIlAt.jpeg)
There is a metal plate under the antistatic mat, so all work/wire holders and lamps are magnetic:
The antistatic mat significantly reduces the magnetic force, so you need stronger magnets.
![](https://i.imgur.com/IaUFRyd.jpeg)
The front lights are old ikea led lights, that I added a magnet base to.
The rear lights are meant for sewing machines/lathes etc.
I replaced the magnets on all the PCBite kit with stronger ones. (That are a few mm too large)
(I haven't actually used the PCBite probes for real yet.)
I added 4 magnets to the stickvise.
The magnets on the omnifixo holders (the ones with the yellow base) were already strong enough.
I repurposed old filing cabinets for nuts/bolts/etc. storage:
![](https://i.imgur.com/8BfuVu6.jpeg)
Each drawer fits 5x Stanley FatMax FMST1-75779 Shallow Organizers.
There are special brackets at the bottom of each drawer, so it's easy to insert an organiser.
And they don't fall over, when you remove one from the drawer.
