Author Topic: When you need a component now!  (Read 766 times)
Offline Dubbie
« on: August 01, 2018, 02:03:16 am »
I was making a little test circuit up this afternoon and needed a certain part.
Problem was I only had it in Xson6 package (1 x 1mm, 0.35mm pin pitch)
I thought I'd have a go at dead bugging it.  Worked a treat! Shows what you can do with a normal soldering iron and a wee bit of flux.
The following users thanked this post: basinstreetdesign
Offline Mr.B
Re: When you need a component now!
« Reply #1 on: August 01, 2018, 02:10:29 am »
Impressive!
I don't think I could keep my hand steady enough.
Time is the overseer of all things.
Offline basinstreetdesign
« Reply #2 on: August 01, 2018, 02:16:22 am »
And I thought I was doing crazy stuff with 0805's.  :clap:
STAND BACK!  I'm going to try SCIENCE!
Offline Dubbie
« Reply #3 on: August 01, 2018, 02:16:46 am »
Kapton tape is my friend! I stuck it all together on the bench first so that a wobble of the iron wouldn't send everything flying. Also meant, if I touched a wire I had done already, it wouldn't pop off again.
Online BravoV
  • +++ ATH1
« Reply #4 on: August 01, 2018, 02:47:45 am »
 :-+  :clap: what great hand & vision you got there.
Btw, I did similar but with bigger sized component, and I added hot glue around the soldered pins at the wires to reduce the stress at the solder joints as we move the cables when using it.
Here what I mean, marked with dark blue circle where I put the hot glue surrounding the chip at the soldered wires.
Offline hans
« Reply #5 on: August 01, 2018, 11:00:35 am »
Nice work!
The smallest packages I've deadbugged were 0.8mm packages (ethernet transformer). I wanted to breadboard a circuit but didn't have any adapter boards that would fit the package.
Advantage: 0402 termination resistors fitted perfectly between the legs of the package. But it was real fiddly to get all wires attached.
Can't imagine if the pitch shrinks even more.. :-/O
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: August 01, 2018, 11:11:41 am »
Nice work!
That exists?
I've got to imagine even if it does, the insertion loss will be ass. ???
Seven Transistor Labs, LLC
